Code P0057 - Needs an o2 sensor, anyone recommend a specific replacement?
Old Oct 2, 2012 | 07:44 AM
GT42R's Avatar
Default Code P0057 - Needs an o2 sensor, anyone recommend a specific replacement?
So my 2003 S-Type R has code P0057 - Heater Control Circuit Low - Bank 2 Sensor 2.
So this is the secondary/downstream o2 sensor on the right side/passenger side of the engine, correct?
I checked the fuses under the hood related to the o2 sensor heater's and they check out fine, so it's safe to assume the o2 sensor itself is up for replacement? Nothing physically wrong with the sensor as far a I can tell.
I am going to order the sensor on rock auto, just wondering which one to go with, if anyone has any suggestions which one may be the best OE replacement.
There is DENSO Part # 2344798 described as "OE manufacturer" and is cheapest at $62.
There is also BOSCH Part # 15626 described as "EXACT FIT 4 WIRE HEATED" and it lists for $77.
Wondering out of these two should which you guys would recommend, thanks!
Old Oct 2, 2012 | 12:36 PM
tbird6's Avatar
If it was me. I would swap the O2 senor I think is bad to the other side before buying anything. The sensor code better follow that move or you have a different problem.
It's kind of weird but with all the 100's of thousands of miles I have driven. O2 sensors are extremely rare to go bad.
Old Oct 2, 2012 | 01:22 PM
GT42R's Avatar
Regarding o2 sensor longevity, I would say the same, however, in this particular case, it's the 'heater' element of the o2 sensor that appears to have failed. Using my OBD scan tool, I can see (once at operating temperature) the sensor itself is operating and reading fine; the heater circuit however appears to be either open or shorted, causing this trouble code. I also consider the fact my STR has custom downpipe's with high flow cat's, so perhaps that's in some way related to what could be considered an early demise.
Good advice with the sensor swap to rule out wiring or circuit troubles, but not sure if its worth the effort in this case.
Old Oct 2, 2012 | 01:45 PM
JagV8's Avatar
Swapping would be good if it were easy (here, they tend to rust/weld in). You can see from JTIS etc that the downstreams are the older type, which are generally substantially cheaper than the newer (linear aka wideband aka AFR) type. Under no circumstances fit the wrong ones or the PCM will be unable to cope.
Old Oct 2, 2012 | 02:07 PM
GT42R's Avatar
Precisely my thoughts regarding removing old o2 sensors, not sure if I want to go through that trouble just to confirm an obvious suspicion. Think I'll pass, and just order, install and cross my fingers.
Mostly wondering which manufacturer o2 sensor people recommend or feel are best OE replacements, thanks.
Old Oct 2, 2012 | 02:57 PM
JagV8's Avatar
I think OE are Denso. Dunno the part # though
Old Oct 2, 2012 | 03:41 PM
abonano's Avatar
Go with Denso...
Old Oct 2, 2012 | 04:15 PM
tbird6's Avatar
I have the O2 sensor socket and on the STR they seem to be sticking out where you can get to them pretty easy. Also a cut heater wire could give that error too.
Old Oct 2, 2012 | 10:15 PM
hollywooddippa's Avatar
I replaced the rear O2 sensor drivers side a couple of years ago. I replaced it with a Denso I got from rockauto. I had to clip the conector of the old one and sauder it on the new one. Worked great and I think I got it for under $30. But the rear one was easy to get to. The old one came off fine...
Old Oct 26, 2012 | 12:35 PM
GT42R's Avatar
As an update, I ordered and received the Denso downstream 02 sensor.
Came with connector, so no soldering needed, and was a straight forward replacement.
Sad news is my CEL came right back, and code p0057 is still present.
I suspect it might have something to do with the ground/body of the sensor itself when threaded into my downpipe, so I'm going to try addressing that and report back.
Old Oct 26, 2012 | 03:30 PM
JagV8's Avatar
Er... did you swap the one on the correct side?
Looks to be bank 2 which is Left (as in LHD).
I don't think the ground/body is relevant to that code, but that's based on logic & elec diagrams rather than being certain.
Old Oct 26, 2012 | 06:39 PM
abonano's Avatar
Did you reset the code with an OBDII reader? If so...
Sounds like you changed the O2 sensor on the wrong side - put the one you removed back in that spot and change out the other side...
Old Oct 26, 2012 | 11:53 PM
GT42R's Avatar
Ugh... You know what, you might be very well correct... Bank 2 I think is in fact the driver's side (LHD) of the engine... man glad someone was here to point this blunder out to me,
think i'll go under the car again tomorrow and do a quick swap...
thanks!
Old Oct 27, 2012 | 01:35 AM
JagV8's Avatar
You wouldn't be the first to do it!! And as you have the part at least it would be a cheap fix if that's all it is
The code should self-clear but it's faster to DIY, either OBD or battery disconnect.
Old Oct 29, 2012 | 10:12 AM
GT42R's Avatar
JagV8, thanks again.
Removed the driver side (LHD) downstream o2 sensor, and replaced it with the old one I removed (mistakenly) the passenger side.
Cleared codes right after, and its been trouble-free since.
Old Oct 30, 2012 | 07:59 AM
JagV8's Avatar
Yayy!
Marka
22
Sep 11, 2016 12:09 AM
Msteiner
May 16, 2016 12:19 AM
carl purchase
Oct 14, 2015 06:14 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
