Codes
Old Oct 20, 2012 | 11:25 AM
rwold's Avatar
Default Codes
I have 2 codes (1647- O2 control chip-bank 2 & 1111- ECM Drive cycle) showing up after my check engine light came on in my 2004 S-type. It doesn't seem to drive any differently and am wondering if it will hurt to drive it short distances until repaired? Also what parts and repair will cost? Any advice appreciated! Thanks.
Old Oct 20, 2012 | 12:36 PM
heima's Avatar
Can't tell you about the P1647, but the P1111 can be ignored. Ironically, it means that all modules have reported in.
Old Oct 20, 2012 | 01:47 PM
You will always see one of these two codes:
P1000 : onboard checks not completed since last memory clear
P1111 : onboard checks completed
As for the other code you've found:
P1647 : HO2 sensor control malfunction - bank 2 upstream
The possible causes are:
1. HO2 sensor 2/1 heater failure
2. HO2 sensing circuit -short to ground, high voltage, open circuit or high resistance
3. ECM failure
You can discount (3) as you wouldn't be driving anywhere!
The effect of (1) and (2) is on emissions monitoring. You may run a little rich or a little weak and push more CO out of the tailpipe. Nothing catastrophic.
I'd clear the codes and run it for a while before checking again. Quite often sensor faults don't recur.
Old Oct 20, 2012 | 10:50 PM
abonano's Avatar
P1647 - Change out the O2 sensor (driver's side O2 sensor right in front of cat converter) www.rockauto.com has good prices and don't forget the 5% off discount code and clear codes.
P1111 - is normal as stated above.
Old Oct 21, 2012 | 08:23 AM
JagV8's Avatar
If you don't change the O2 the car will estimate the fuelling, erring on the rich side, and (probably slowly) burn out the catalytic convertor.
Old Oct 22, 2012 | 10:57 AM
clubairth1's Avatar
Community Influencer
You can change the O2 sensor but I would the clear codes first. Make sure it comes back and is the same sensor.
Then before buying anything swap the O2 sensor from side to side. The fault code should follow the sensor.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
