Cooling Fan Module for 2001 3.0L (early VIN)
Old May 31, 2021 | 02:39 PM
LCSchuette's Avatar
Default Cooling Fan Module for 2001 3.0L (early VIN)
Hi,
New to the forum, but I searched enough to know this is the right place, but I didn't see the answer...
Daughter's 01 Jag S-type has what appears to be a bad control module. I see that is a popular problem (Fan spins with 12v applied, low voltage (1.2v) from the module when turned on/AC on.).
Is there a part # for the adapter cable/new module that I see referenced elsewhere on the forum? Or a link on the forum that will explain my path forward?
Alternatively, anyone have a good module for sale? (either old style, or new style + cable).
Thanks in advance,
Larry
Old Jun 1, 2021 | 11:47 AM
abonano's Avatar
Larry,
I think I have one off of a 2000 S Type.
Can you please respond back with the part number that's listed on the module and I can confirm on my end.
Best - Anthony
Old Jun 1, 2021 | 06:51 PM
LCSchuette's Avatar
Thanks! DrDome is going to look at his supply, but the part # is XR86419. I'm about to go remove it to confirm, and then decide if I want to take it apart before the replacement arrives!
Best
Larry
Old Jun 1, 2021 | 07:22 PM
LCSchuette's Avatar
I got the airbox out of the way, and disconnected the connector to the module, but it's not obvious what is holding the module to the fan shroud. It's nicely enclosed in a plastic shroud... Anyone removed one? Searched online and didn't see any pointers...
Thanks,
Larry
Old Jun 1, 2021 | 07:34 PM
LCSchuette's Avatar
Thanks,
Larry
OK, thank you ebay for having images of fan shrouds from lots of angles. I could see the seam in the plastic cover, and a right angle pick made quick work of removing it (without breaking the antique plastic!).
Old Jun 1, 2021 | 08:25 PM
LCSchuette's Avatar
So, this module is a JAGUAR XR838C609AA, GATE 940.0000, HKR System E5004.001.
Uscrewing the backside reveals an unremarkable circuit board marked 721-5004.1g in the copper tracing. Board has 6 1000uF, 35V, 105degree C rated electrolytic capacitors - none of the caps appear damaged, and 5 3 pin devices (presumably MOSFETS, 4 in TO-220 packaging, one larger. They are thermally coupled to the case via spring loaded fingers and dielectric grease.
Sadly nothing looks wrong...
Old Jun 4, 2021 | 04:50 PM
NBCat's Avatar
Does the radiator fan run with the ignition in the OFF position after the vehicle has been fully warmed up?
Old Jun 4, 2021 | 05:55 PM
LCSchuette's Avatar
No. The fan never turns on - with temperature, or with AC... I ordered a new used module. And then I'm going to pull the MOSFETS off and test them.
ATB
Larry
Angelicaxtype
Nov 10, 2017 09:01 AM
m2001mv
Jul 22, 2015 05:49 AM
herzeleid
Jun 25, 2013 08:55 AM
mattr
Mar 7, 2013 01:55 PM
MosDefXType
Jul 21, 2011 07:59 PM
