Eng Chip Light
Old May 16, 2019 | 07:20 PM
Chuck Schexnayder's Avatar
Default Eng Chip Light
On Start and all Starts after, only, I get A chip light.
If I clear the light, it does not come on again until I start the engine again. Has never come on while running.
Any one with past knowledge[ ever have this problem? V-8 , 4.2
Chuck
Old May 16, 2019 | 11:52 PM
kr98664's Avatar
Chuck, I'm not familiar with a "chip light". Are you talking about the check engine light on the dash?
Old May 17, 2019 | 08:26 AM
aholbro1's Avatar
I'm betting Chuck is in aviation......
Old May 17, 2019 | 10:06 AM
S-Type Owner's Avatar
I am also wondering how he is "clearing" the light...? If using a diagnostic tool to do this, then why not just run a scan?
Old May 17, 2019 | 03:53 PM
Yeah your right, in aviation for almost 40 years... Sorry about the confusion, "it's "Check Engine Light" not Chip Light. Old farts get a little rusty at times....
Chuck
Old May 17, 2019 | 04:35 PM
aholbro1's Avatar
Press the fuzz-burn button (but only allowed 3 per flight) or pull the chip detector, clean the magnet, analyze the particles, and maybe do a penalty-turn...or something like that....right Chuck?
Old May 17, 2019 | 04:43 PM
Chuck, you need to get the codes read to identify the cause.
If you don't have a scanner any of the auto stores will do it for you.
Old May 17, 2019 | 05:11 PM
kr98664's Avatar
Originally Posted by aholbro1
clean the magnet, analyze the particles...
Per one of my leads many years ago:
"If you can't read a serial number on any of the chips, the engine is good to go."
Old May 18, 2019 | 06:11 AM
JagV8's Avatar
+1
You can probably then look them up on this site to see what to do.
Old May 18, 2019 | 05:43 PM
scottjh9's Avatar
Hello Chuck
If i remember right you went through a fuel pump issue earlier this year.... whatever codes are retrieved surely post them as jagv8 has said....if they are fuel related, you might be under warranty...either way the members will surely get you sorted out....even if you buy your own code reader, they are easy to use
chisjc
Dec 21, 2010 08:49 AM
micktenbosch
XJ40 ( XJ81 )
Sep 27, 2010 08:58 PM
williespinks
Aug 29, 2010 11:14 AM
JagJoel
Apr 4, 2008 08:10 PM
