engine
Old Apr 11, 2022 | 08:26 AM
knares's Avatar
Default engine
s-type v6
i have an 2003 v6, what make engine is it fitted with, i did read some where that it had a ford engine
so my question is what engine has my car got and do all s-types have the same v6
Old Apr 11, 2022 | 08:42 AM
S-Type Owner's Avatar
Your engine is a Duratec V-6, with specially designed Jaguar cylinder heads. The original design engineering was purchased from Porsche and was refined by Cosworth. Engine management systems were changed to a Denso system in 2002.5 in your area of the world with the other X202 revisions. The engine was built in the Cleveland Engine Plant #2 and is a very good "mill"...
Old Apr 11, 2022 | 08:58 AM
knares's Avatar
thanks, so what is a AJ-v6, is that the same engine
Old Apr 11, 2022 | 10:25 AM
xalty's Avatar
not a duratec. you have the JV6, in the 03+ it’s the AJ62. before is AJ60
JV6 uses the same block and bottom end components as the 60 degree modular V6 but very different heads.
Old May 10, 2022 | 08:28 AM
2000 s-type boy's Avatar
Who makes the 3.0 liter in my 2000 S-Type? someone said Ford, but it doesn't look like any Ford motor I have ever seen.
Old May 10, 2022 | 09:15 AM
The bottom end is basically a Duratec V-6, but the cylinder heads and intake were designed by Jaguar. The engines were produced in Ford's Cleveland Engine Plant #2. The original window sticker on my 2003 even states USA as the origin for the engine and Germany for the origin of the transmission, IIRC.
Old May 11, 2022 | 10:39 AM
NBCat's Avatar
https://en.wikipedia.org/wiki/Jaguar_AJ-V6_engine
Old May 11, 2022 | 10:49 AM
xalty's Avatar
somebody needs to clean up this article the person who wrote it has zero clue about the variants and their numbering
JaguarXKR
Jan 9, 2025 09:31 AM
Chester7
Sep 8, 2018 03:31 PM
pab
XE ( X760 )
May 11, 2016 08:17 PM
seagates5
May 12, 2015 02:11 AM
