Engine Code 403
Old May 16, 2012 | 03:21 PM
weldboy's Avatar
Default Engine Code 403
I have an 02 S Type 3.0 and I got this engine code today Code 403 EGR Flow Circut Malfunction. Cars seems to run ok. Any ideas what part would be malfunctioning?? Thanks
Old May 17, 2012 | 08:22 AM
abonano's Avatar
Um, the EGR (Exhaust Gas Recirculation) valve would be malfunctioning... check the electrical connector or the EGR for blockage/soot... if you don't have JTIS - it's a good time to download off the forum - the info contained is very beneficial.
Old May 17, 2012 | 09:30 AM
weldboy's Avatar
Great I'll check them out. Thanks
Old May 17, 2012 | 12:59 PM
weldboy's Avatar
Unhappy
My 02 S Type 3.0 doesn't have a EGR Valve on it, it's blocked off from the factory. So now what would set the engine light on with the code P0403 if there is no EGR Valve ???
Old May 17, 2012 | 01:06 PM
QuartzSTypeR's Avatar
There could be blocked off passages in the EGR tubes or excessive carbon buildup.
Old May 17, 2012 | 01:20 PM
weldboy's Avatar
Unhappy Engine Code P0403 Help!!!
Originally Posted by weldboy
I have an 02 S Type 3.0 and I got this engine code today Code P0403 EGR Flow Circut Malfunction. Cars seems to run ok. Any ideas what part would be malfunctioning?? Thanks
I've since checked and I don't have a EGR Valve on my engine, So what would set that code off ???????
Old May 18, 2012 | 08:47 AM
JagV8's Avatar
Why no EGR? Jag tech doc show you have one.
Old May 18, 2012 | 09:30 AM
abonano's Avatar
Weldboy...Time to take your Jaguar to a mechanic, who can sort out the issue for you! Good Luck..
Old May 18, 2012 | 10:16 AM
joycesjag's Avatar
EGR Valve should look like this:
Old May 18, 2012 | 04:51 PM
weldboy's Avatar
There's a block off plate that is from the factory. I've read somewhere else that somebody had a 2002 S type with the 3.0 that didn't have a EGR Valve too!!! I've cleared the code and it hasn't come back on in 50 miles of driving so far.
Old May 18, 2012 | 05:07 PM
JagV8's Avatar
Sounds like a non-CA, possibly non-USA, car.
Old May 18, 2012 | 05:27 PM
weldboy's Avatar
How can you tell if it's a non-US car. I bought it about a year ago and just assumed it has always been in California.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 2, 2015 12:48 PM
