EPB - how to turn it off?
Old May 26, 2012 | 02:12 PM
jamStypeR's Avatar
Default EPB - how to turn it off?
I'd like to disable the EPB. Do I have to remove only a fuse?
S Type R 2003
Old May 27, 2012 | 08:32 AM
JagV8's Avatar
Could you cope with just disabling it when you need to? It's the Emergency brake so it's not ideal to permanently disable it.
You can stop it engaging any time just by holding the paddle down as you remove the key.
Old May 28, 2012 | 09:42 AM
jamStypeR's Avatar
I know the trick with the paddle and I also know it's an emergency brake but I'd like to ride the car for a few miles without it. It looks like there's a clearance problem with the new EPB pads so I don't want to damage the new rotors.
Old May 28, 2012 | 11:46 AM
Mikey's Avatar
If your new pads are rubbing the rotor with the EPB off, pulling a fuse or playing with wiring will change nothing, they'll still rub.
Old May 28, 2012 | 12:21 PM
jamStypeR's Avatar
I won't install the EPB pads. I just don't want the piston to go too far because there's no pads
Old May 28, 2012 | 12:33 PM
jag79's Avatar
Amigo, don't take the risk, those aftermarket EPB's you bought isn't worth causing more problems for you. Best bet just buy the OEM EPBs for the STR from Nalley Jaguar(mention your a jaguar forums member to receive discount) and your set.
Good Luck...
Old May 28, 2012 | 12:58 PM
I don't have an S Type, and I'm thinking that JagV8 or Mikey may quite rightly think me way off target.
But if your new EPB pads are rubbing because they are slightly thicker than OEM, why not simply sand them down until they are the correct thickness, and then install them.
After all, that is what your rotors do, over a longer period.
This assumes that the EPB is working correctly in the first place.
Old May 28, 2012 | 01:00 PM
Mikey's Avatar
You might want to tell us the whole story to help with getting useful answers. If you're driving the car to a garage to get the new brakes installed and working properly, simply reinstall the old pads for the trip.
Old May 28, 2012 | 01:01 PM
Mikey's Avatar
Nope, you're spot on!
Old May 28, 2012 | 01:05 PM
It should be F35 in the boot.
Why not just tell us the full story to start with?
Old May 29, 2012 | 08:41 AM
JagV8's Avatar
I'm with Mikey, careful sanding down should be OK (and far better than disabling EPB or leaving pads out!!) - but is that the actual issue?
JarodL
Mar 7, 2024 01:39 AM
RaceDiagnostics
Jul 7, 2022 06:41 AM
Malihide
Apr 2, 2016 04:05 PM
abonano
25
Sep 25, 2015 10:43 AM
ZJag
Sep 15, 2015 03:39 PM
