fuel filler
Old Dec 2, 2012 | 03:58 AM
darren-talbot's Avatar
Default fuel filler
annoying little problem everytime i fill up with petrol the pump keeps clicking off after 10 secons so as you can imagine it takes me ages to fill up, what would be the problem?
its not the petrol pumps because its done it at all different pumps so its the car, just not sure what id need to replace?
Old Dec 2, 2012 | 04:08 AM
jimgoose's Avatar
Mine does that a bit too. I don't know why these cars seem particularly sensitive, but I find pulling the nozzle back slightly while filling helps. And with some pumps I just have to "throttle" the flow until it decides to behave itself. It can be a little annoying.
Old Dec 2, 2012 | 04:30 AM
yeah i found throttling the pump works a little bit too.
Old Dec 2, 2012 | 04:34 AM
Premier1one's Avatar
must have a tight bend that restricts the flow, maybe someone can come up with a design to reroute the filler line with less aggressive bends
Old Dec 2, 2012 | 09:00 AM
JagV8's Avatar
I think the vapour in the tank that gets displaced is meant to flow through the carbon canister but if that doesn't happen the pump sees it instead and cuts off the fuel. So you're looking at something wrong in the canister path.
Old Dec 2, 2012 | 02:38 PM
police666's Avatar
I find twisting the pump to the side helps on the few occasions it's happened to me
Old Dec 2, 2012 | 04:16 PM
how do we fix this canister path problem?
it is frustrating.
Old Dec 2, 2012 | 04:38 PM
JagV8's Avatar
Look in JTIS...
1100me
Jul 24, 2023 06:10 PM
kelliott
May 31, 2022 05:26 PM
reb1999
Sep 25, 2015 10:00 AM
njburlington
Sep 24, 2015 08:40 PM
puddled
Sep 22, 2015 03:57 AM
