Gearbox Fault
Old Jul 12, 2015 | 08:36 PM
tomygun88's Avatar
Exclamation Gearbox Fault
So my 2005 S Type 3.0 GearBox Fault warning is on.
P R N all work fine. But when I go into D it goes very slow, sounds and feels like its stuck in a higher gear and wont come out.
Old Jul 13, 2015 | 01:20 AM
JagV8's Avatar
How about 2,3,4,5?
Old Jul 13, 2015 | 08:04 AM
tomygun88's Avatar
Those dont work as well. Nor does Sport mode
Old Jul 13, 2015 | 11:42 AM
joycesjag's Avatar
How many miles? Have you noticed any leakage of Lifeguard Fluid.
Check the easy stuff first. If you cannot DIY check the fluid level take it to any transmission shop and have them check it.
Old Jul 13, 2015 | 12:14 PM
tomygun88's Avatar
But the tranny was replaced about 1 1/2 ago. And of course it only had a 1 yr warranty. No fluid leaking that I can see.
Old Jul 13, 2015 | 12:27 PM
tomygun88's Avatar
Just called the shop that did the replacement. Of course all they can do is "take a look at it" Its a sealed tranny, that Im sure consists of literally looking at it and doing another swap. $$$
Old Jul 13, 2015 | 12:40 PM
JagV8's Avatar
They're not sealed. They have a fill plug that's also used to check the level. If your place don't know how to do the level check then go elsewhere - any competent trans place should nowadays know this quite common box. It's used on Audis, BMWs, Aston Martins, Bentleys, Fords, etc.
Old Jul 13, 2015 | 12:45 PM
tomygun88's Avatar
Oh lovely. I can only assume the fluid is good. Havent had any leaks since it was replaced.
JaguarLover101
48
Jun 12, 2023 10:28 AM
3lvis
Oct 1, 2015 01:56 PM
dmatthewman
Sep 30, 2015 10:10 AM
jjmiah217
Sep 28, 2015 09:09 AM
