head gasket kit
Old Jul 31, 2011 | 06:34 PM
therave's Avatar
Default head gasket kit
ok anyone know where i can get a gasket kit for the top of my 3.0l v6 vin-fl33299. thats less than £300?
Old Aug 1, 2011 | 02:47 AM
Cadillac's Avatar
DUCKWORTH PARTS , one of our vendors
www.britishparts.co.uk
www.ebay.co.uk
Hope these help you out
Old Aug 3, 2011 | 05:07 AM
therave's Avatar
ta! £290+vat i wonder if the ford 3.0 v6 is the same its only £60
Old Aug 5, 2011 | 08:25 AM
therave's Avatar
i came to the head gasket, but is it? no smoke today but it did yesterday right hand pipe , no water in oil, no oil in water never has been and runs ok not lumpy. ideas!
Old Aug 5, 2011 | 09:42 AM
From your intro thread you say that it is heating up fast, is it overheating.
Maybe you should start with a pressure test on the cooling system and check the thermostat?
Old Aug 5, 2011 | 10:56 AM
therave's Avatar
no its not over heating, did a pressure test and it seems fine
Old Aug 5, 2011 | 11:23 AM
JagV8's Avatar
Seems like there must be a more coherent and all-in-one description of the problem just in case someone can figure out the things to do.
Old Aug 5, 2011 | 12:16 PM
therave's Avatar
just had plugs out of left bank all look ok.
Old Aug 5, 2011 | 12:21 PM
I agree, what exactly is the problem?
If you give some details maybe someone can help.
Old Aug 5, 2011 | 12:33 PM
therave's Avatar
the car is smoking and it looks like steam
Old Aug 5, 2011 | 12:47 PM
JagV8's Avatar
Well, I tried.
Old Aug 5, 2011 | 12:58 PM
therave's Avatar
What info would you like?
Old Aug 5, 2011 | 02:41 PM
JagV8's Avatar
If that's all you have I think you need to gather a lot more.
Old Aug 25, 2011 | 07:42 PM
therave's Avatar
Well i got the heads off, yes one cylinder was clean, must have been all the water in there. New head bolts are on there way £2.00 each(had to ask in one of my posts why), head gaskets £40 for the two. head skim £60 for the six pots. About £50 for the rest of the gaskets with intake upper and lower in that, spark plugs £22, oil asda(walmart) £20 5ltr full synthetic oil filter £4. I don't think thats bad for a diy'er with a small box of tools, if you want to play with a s-type get a dam good 8mm and 10mm (just like ford). Come to think of it all the gaskets are ford (well well).
Ok just got to rebuild it when all the parts have come, that sould be more fun and then i will find out if this is a diy car.
replace a sill next, because the last owner could not read where to put the wheel jack.
I was going to put some pics on but dont know how.
Old Aug 26, 2011 | 03:02 AM
Cadillac's Avatar
therave, you can see this link below :
https://www.jaguarforums.com/forum/j...essages-36173/
However, assuming you're still a junior member then you may not use this procedure above then embedded [IMG] [ / IMG] tags between http links w/o any space
Old Sep 2, 2011 | 05:24 PM
therave's Avatar
well the heads came back from the shop bang on price £60 uk.
Started today rebuliding just had a hour one head back on, the chain tensioner was a bit of a pain reseting it, so not that bad up to now.
my night time reading for the last week has been jtiss,
Its around 20years since i played with engines and i dont think this one is
particulary hard well not as much as i was expecting.
Attached Thumbnails head gasket kit-img_0483.jpg   head gasket kit-img_0478.jpg   head gasket kit-img_0484.jpg
Old Sep 4, 2011 | 07:30 AM
clubairth1's Avatar
Community Influencer
Very rare for you to lose a head gasket?? Fist one I ever heard of? Can you explain how it happened?
Old Sep 4, 2011 | 04:55 PM
therave's Avatar
i dont know, this was how it was when i got the cat. when i picked it up it did seem to run fine but i had a steam room following me, got home and there was a water leak that had been there for some time. i think the head over heated. reading the forum it does happen. also the cat has over 180000 miles on the clock.
duecedriver
Dec 25, 2015 11:47 AM
vicom
Sep 17, 2015 03:32 AM
bavareze
Sep 11, 2015 01:49 AM
1964Daimler
Sep 9, 2015 11:28 AM
1964Daimler
Sep 9, 2015 11:20 AM
