Headlights
Old Nov 28, 2016 | 02:29 PM
Mikep3075's Avatar
Default Headlights
Does my 2004 S Type have Halogen or Xenon headlights?
Old Nov 28, 2016 | 02:46 PM
Jon89's Avatar
You need to supply your VIN before anyone can check that for you. You could also contact a Jaguar dealership and ask them to print the factory build sheet for you. It's always a good idea to have the build sheet in hand for any vehicle you own. Again, you would need to supply them with your VIN....
Old Nov 28, 2016 | 02:52 PM
Mikep3075's Avatar
Vin SAJAC01N35JN30617
Old Nov 28, 2016 | 03:11 PM
JagV8's Avatar
Looks like halogen
See FordEtis home page
You're lucky - easy to change a bulb, don't have powerwash that can fail, motors that fail, etc
Old Nov 28, 2016 | 03:17 PM
Mikep3075's Avatar
Am looking to upgrade my headlights to H7 Philips Racing Vision +150% 12V 55W 477 look pretty good on youtube
Old Nov 29, 2016 | 06:00 AM
Busa's Avatar
The xenon bulbs are a nice bright white light, so to look right you'll need to change the sidelight bulbs and both dipped and main beam bulbs.
I didnt change the sidelight bulbs at first, then I could see how yellow they were.
The same for the fog light bulbs which I havent changed yet.
By fitting 55W xenon bulbs to mine its improved night time vision and safety of course. With titanium paint the bright white lights look great.
Old Nov 29, 2016 | 07:45 AM
Mikep3075's Avatar
I have halogen lights which use halogen bulbs can i replace them with Xenon bulbs?
Old Nov 29, 2016 | 07:55 AM
Mikep3075's Avatar
Does anybody use LED canbus bulbs
Old Nov 29, 2016 | 08:05 AM
pab's Avatar
pab
>Looks like halogen
Lucky you, my HIDs have cost me a bundle and I really don't think the brightness justified the price (get off my lawn...)
Jaguar - it's not an automobile, it's a Motorcar
2015 JCNA National Slalom Champion Class M
Current: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past: '05 X-Type 3.0/auto Jaguar Racing Green
Old Nov 29, 2016 | 10:12 AM
Busa's Avatar
Originally Posted by pab
>Looks like halogen
Tbh I've not heard a good thing about HID kits on cars or bikes.
Sorry to hear yours havent worked out so good.
Old Nov 29, 2016 | 10:28 AM
Busa's Avatar
Yes you can swap the halogen for xenon in the headlights same as on my 02 car.
You need the generic reference for each bulb type for your car and then use those to find xenon replacements. ie: H7, HB3 etc
These are what I have fitted, but they might not be the same on yours being a later model.
Headlight bulbs dipped beam: H7 55W Super White Xenon HID
Headlight bulbs main beam: HB3 65w Super White Xenon HID
Sidelight bulbs: T10 W5W 6 LED white Xenon
I use well established UK motorfactors on eBay because they charge a lot less than high street shops. I fitted them myself without any major problems apart from the space being a bit tight for my hands. Making sure not to touch the glass part of the new bulbs with my fingers of course.
Old Nov 29, 2016 | 12:39 PM
pab's Avatar
pab
Nope, mine are the real thing, straight from Jaguar, suffered from the familiar drooping light syndrome. Cost me $1400 to have the dealer replace one light assembly (hadn't learned of the "brutal" screw fix).
Still don't think they're particularly brighter than conventional lights.
You dreamed of a big star -
He played a mean guitar -
He loved to drive his Jaguar...
So welcome to the machine
Old Dec 8, 2016 | 09:45 AM
Rambunctious Jaguar's Avatar
Hi All,
anyone with pictures that have fitted xenon or canbus bulbs ? I would like to see a comparison.
In my pursuit for increased illumination I have retro fitted aftermarket projectors and Hid bulbs/ballasts.
I can post pictures of light output later.
Old Dec 11, 2016 | 01:40 PM
cut off shroud down
cut off shroud up
Old Dec 11, 2016 | 02:47 PM
JagV8's Avatar
Are those the dipped headlights or main beam ones?
Old Dec 12, 2016 | 04:57 AM
Hi,
Both images are of the low/dipped beam, HIDs inside of Morimoto fx-r projectors . My main/high beams are standard oem bulbs.
Old Dec 12, 2016 | 05:26 AM
JagV8's Avatar
So why wouldn't you use the main ones on a road like that?
Old Dec 12, 2016 | 09:38 AM
sjgh's Avatar
Those look very bright as low beams. Would be interested in knowing how you went about installing/fitting the offmarket projecters and ballast.
Old Dec 23, 2016 | 09:16 AM
Hi Jagv8, my main beams(high beams) are stock bulbs and are very low in light output in comparison.
Sjgh,
This took a lot of trial and error and modification of the stock housings. the installation of the HID is relatively simple in comparison to the mounting and alignment of the after market projector into the reflector portion of the headlight.
I have taken a few more pictures, the first picture is of the regular low beam 1/2 output, you can see the sharp cutoff limiting the light output.
Second pictures is of low beam at full output.
1/2
full output
