help on brake calipers
Old Jan 29, 2012 | 09:48 PM
Jag Breeder's Avatar
Default help on brake calipers
Can someone please help me with an installaition will the brembo brake caliper of the s type r bolt up to an 2001
s type 3.0 v6
Old Jan 29, 2012 | 10:11 PM
joycesjag's Avatar
Simply put, NO!
Old Jan 29, 2012 | 10:52 PM
Is there any way I can get it to bolt up
Old Jan 29, 2012 | 10:58 PM
NBCat's Avatar
You want to accomplish this because..........???
Old Jan 29, 2012 | 11:49 PM
I like those brake caliper styles and I read that they are reliable plus they look marvelous on the s type
Old Jan 30, 2012 | 12:08 AM
NBCat's Avatar
While other modifications are relatively harmless or appeal to the 'boy racer' in some of us, modifying the braking system is more serious and requires more thought.
The braking systems on most modern vehicles incorporate electronic brake force distribution based on weight bias as well as balancing the antilock brake system sensors with computer modules. This is without considering the diameter of the master cylinder bore and the caliper piston displacement(s), which determine the pedal feel and response.
Having taken all these variables into consideration, one can embark on modifications to the braking system. Are you going to use your vehicle for racing or time trials and what are you intending to do with the front calipers?
NBCat
Old Jan 30, 2012 | 03:10 AM
JagV8's Avatar
Bear in mind the STR has very modified suspension from a 2001 car AND the rear brakes are twofold: Brembo and separate handbrake (EPB). You're going to really struggle to do it. Really.
I wouldn't start
Old Jan 30, 2012 | 12:07 PM
Thanks for the information and knowledge on the system I might just put the covers on therefor there looK's you guys are awesome
Old Jan 30, 2012 | 02:03 PM
gabrielduenas's Avatar
check this out:
post number 68, the LS owner gives up. I believe your 01 S type has the same suspension, Jaguar S-Type-R brake and wheel upgrade - Page 3 - Lincoln vs Cadillac
I am in the process of slowly collecting parts for a similar porject. I have a 03 Stype Sport and so far my list of parts that need replacement are:
Steering knuckles, hubs, rotors, dust shields, brake lines, calipers, caliper bolts, wheels for the front.
So far i have 19" wheels and the STR front calipers lol
Old Jan 30, 2012 | 02:06 PM
JagV8's Avatar
I don't see the EPB parts, which I reckon you'll need.
Old Jan 30, 2012 | 02:24 PM
vance580's Avatar
I think he is only doing the fronts. If he was doing the rears also he would probably need alot more then that. May be cheaper to just sell and get an STR. 03's arent priced to bad. Also you may want to check if the master cylinder is different between the STR and S type. May be different since the STR's is pushing 16 pistons. Something else to check on.
Old Jan 30, 2012 | 06:05 PM
Yea I've been doing research and with all the things that I might have to upgrade and replace ill rather just do what vance recommend thank y'all again
wvanepps
Oct 4, 2015 10:01 AM
GT-Z
Sep 23, 2015 03:50 PM
Jagman28
Sep 14, 2015 01:37 PM
Richard_gib
Sep 11, 2015 08:02 PM
JagLove86
Sep 6, 2015 10:36 PM
