Helppppppp!!
Old Oct 22, 2011 | 07:00 AM
cue244's Avatar
Default Helppppppp!!
I was driving this morning and my check engine light popped on. It says solid while I am at a light, but once I start moving, the light flashes. Also it will run really ruff once I get to a steady speed and it idles ruff as well. Any ideas??? Of course on a weekend too!
Old Oct 22, 2011 | 07:04 AM
joycesjag's Avatar
cue we need codes buddy!
Old Oct 22, 2011 | 07:13 AM
cue244's Avatar
I will stop at Autozone on the way home from work (if I make it) and have them get a code
Old Oct 22, 2011 | 07:20 AM
cue244's Avatar
I also just degreased and washed the engine last night.
Old Oct 22, 2011 | 08:58 AM
cue244's Avatar
I removed the coils and found water in them. I blew them out and now have the car outside idleing for a hour but it still is running rough. I could only get the coils and plugs on the driver's side.
Old Oct 22, 2011 | 08:59 AM
cue244's Avatar
Can I drive it home, like 15 miles?? I can take the highway home or back roads.
Old Oct 22, 2011 | 09:18 AM
clubairth1's Avatar
Community Influencer
Hopefully you will read the forum in some detail. All of what you are going thru has been done before.You did learn one good lesson already.
DO NOT wash the engine bay!!!
If you want to clean it use a rag and a spray bottle. Yes it's more work but you got off lucky this time. If you foul a throttle body the cost will be much higher.
Old Oct 22, 2011 | 09:24 AM
cue244's Avatar
Lesson leaned for sure!!! Any more ideas on how to fix my car?
Old Oct 22, 2011 | 10:03 AM
bfsgross's Avatar
You can drive her the 15 miles home...here you'll dry all the coils, throttle body and MAF connectors too. Keep us posted.
Old Oct 22, 2011 | 10:09 AM
cue244's Avatar
Thanks I will for sure.
Old Oct 22, 2011 | 11:08 AM
JagV8's Avatar
Ideally you'd make sure everything is waterproof but otherwise wash with more care
Flashing MIL = catalyst-damaging misfire. Bad news but not terminal if you get it fixed before it's too late. They'll take SOME abuse.
Old Oct 22, 2011 | 11:39 AM
cue244's Avatar
Code reader said misfire 4 and 6. I picked up three new coils and all new plugs. They have to order three more coils. Guess I will do the side that is misfiring now and the rest later.
Old Oct 22, 2011 | 03:52 PM
bfsgross's Avatar
Everything will be ok, Amen.
Old Oct 24, 2011 | 09:03 AM
cue244's Avatar
Ahhhhh, new plugs and coils = one happy car again. I found that my car had the orginal plugs and coils on her. Thanks for all the advice!!!
