How much torque on Upper A arm bolts.
Old Aug 10, 2013 | 08:39 PM
jackatg450's Avatar
Default How much torque on Upper A arm bolts.
When I replaced my upper ball joints on my 2005 S- Type, I tightened the A-arm bolts until the arm was stiff, then loosened until "free". Should I go back and retighten them and to what torque?
Thank You,
Jack
Old Aug 10, 2013 | 08:56 PM
plums's Avatar
They will need to be re-tightened while sitting on the tires or with the weight on the suspension supported by a jackstand.
If you are in a hurry, the JTIS download probably contains the information.
Otherwise, someone who owns a S-Type will probably chime in.
Old Aug 11, 2013 | 07:54 AM
clubairth1's Avatar
Community Influencer
I would also get the JTIS and follow the instructions. It's free on this site.
Old Aug 12, 2013 | 07:13 PM
jackatg450's Avatar
Default Jtis
I looked at the instructions on the install, and then discovered it covered up to 2004. I ordered a Repair Manual CD on E-Bay that covers up to 2008. I should receive it in about another week. I will post how that turns out.
I have some free time tonight, I will look at installing again.
Thank you
Jack
Old Aug 12, 2013 | 07:26 PM
plums's Avatar
Hopefully someone who knows for your model and year can get you the answer without waiting for the CD.
Old Aug 13, 2013 | 12:02 AM
JagV8's Avatar
Almost for sure the same as 2004.
Old Aug 13, 2013 | 03:11 PM
jackatg450's Avatar
Default I found my answer.
I called the service manager at Parretti Jaguar in New Orleans, she connected me to a service tech. He said to use a 17mm end wrench and tighten as tight as I could get it. I ask about a torque value, he said as tight as I could get it.
Jack
Old Aug 14, 2013 | 01:45 AM
JagV8's Avatar
Worth what you paid for it.
Old Aug 17, 2013 | 03:57 AM
grandhaze's Avatar
Tighten all the way because the bolt holds the centre sleeve still and the rubber moves/ stretches with the outer. Which is why you tighten it once weight taken by wheel or jack. Paul
Johnken
Apr 8, 2018 10:21 AM
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
Blake04VDP
Sep 28, 2015 05:20 PM
Camnelson324
Sep 27, 2015 08:48 AM
