Inspection
Old Jan 12, 2014 | 10:40 PM
jaguarx00's Avatar
Default Inspection
My car has the DSC light on, getting my inspection done soon..will that effect the outcome of it passing? Thanks
I live in Texas .
Old Jan 13, 2014 | 07:46 AM
I expect it will.
You need to get the codes checked and determine what is causing the light to show.
Old Jan 13, 2014 | 09:32 AM
abonano's Avatar
Yes, +1 you will more than likely not be able to pass inspection. As Norri suggested obtain an OBD2 scanner capable of accessing the ABS module - that is where your code(s) are stored.
Old Jan 13, 2014 | 11:02 AM
JagV8's Avatar
Sadly, most ordinary OBD tools won't provide those codes
It's often a rear reluctor or sensor so you might try cleaning and hope.
Old Jan 13, 2014 | 11:22 AM
jaguarx00's Avatar
Thanks guys just don't want spend 175$ just for the dealer to take a look at the car when it could be something as easy as a sensor.
Old Jan 13, 2014 | 12:39 PM
abonano's Avatar
I hear you - check out the thread "approved scanners" - I always hear that the ELM327 is a good option to retrieve codes.
I have had general luck with a Matco Determinator to gain access into the ABS sytem (through the Ford Domestic application) - however, I recently scored a deal on a Jaguar WDS analyzer - so no more trips to the dealership!
Old Jan 13, 2014 | 01:17 PM
JagV8's Avatar
The elm327 is great but the software won't fetch ABS module codes.
Old Jan 13, 2014 | 04:40 PM
jaguarx00's Avatar
Originally Posted by abonano
I hear you - check out the thread "approved scanners" - I always hear that the ELM327 is a good option to retrieve codes. I have had general luck with a Matco Determinator to gain access into the ABS sytem (through the Ford Domestic application) - however, I recently scored a deal on a Jaguar WDS analyzer - so no more trips to the dealership!
Must be nice
Old Jan 14, 2014 | 08:06 AM
abonano's Avatar
Originally Posted by jaguarx00
Must be nice
Yeh, it sucks having to rely on the dealership for these common problems - wish the OBD2 cord was long enough to reach TX - I's hook you up!
Old Jan 14, 2014 | 01:49 PM
tbird6's Avatar
Hey how much did the WDS run you?
That would be the ultimate for a shade tree mechanic!
Might be tough getting the latest software updates?
Old Jan 14, 2014 | 02:26 PM
JagV8's Avatar
It was frozen years ago I think (but good for the things it covers). I'd like it & IDS/SDD if I were to work on the cars as the techs do (not something I do want to do!).
LnrB
Oct 13, 2015 12:45 AM
redxk8
Oct 4, 2015 08:28 AM
inactualis
Oct 2, 2015 11:13 AM
Woznaldo
Sep 26, 2015 11:02 AM
