Intercooler Pump
Intercooler pump on my 2005 STR is getting no power. i was getting ready to change it to the 010 when i put a test light on the wires and i wasn’t getting anything with the car in the run position. the fuse is getting power
On the passenger side right of the alternator are 3 seperate plug in connections. Jaguar calls it the cooling module plug ins. A very common fault is pin corrosion on the plug in that has the intercooler pump in it. I had the exact same issue and found bad pins that i bypassed with new wires. I think you can access this area by removing the right front wheel and it is behind the wheel liner close to the sub frame rail. You cannot miss it because of the amount of wires coming and going
There are 2 coolant pumps on your car. So make sure which one your working on.
Do you know where they both are? The inter cooler pump is on the front of the radiator and usually accessed by removing the front bumper. The AUX coolant pump is on the inside of the radiator and is accessed by removing the top coolant tank. But they are both on the passenger side of the engine. AUX pump is mounted higher than the inter cooler pump.
I have worked on the inter cooler pump by removing the plastic cover under the front bumper but it's very tight doing it that way.
IC pumps are on all the time. Most of the time when you turn the key and power up the car. Some only when the engine is running. So I always make sure the engine is running when I check for power.
Yes the intercooler pump that feeds into the intercooler itself near the bumper, and i also had the engine running but no power at all...
there is one with 2 large gauge wires for the fan. There is one with 10 or 12 wires and i think the intercooler pump is in that plug. Best i can remember. Sorry. Either way you should check all 3 for corrosion
AlexJag
Jun 14, 2024 03:17 PM
WinterJag
Aug 17, 2013 07:33 PM
