Intermittant driver's window
Old Dec 10, 2014 | 11:52 PM
rattlenbang's Avatar
Default Intermittant driver's window
About once a week the window doesn't move, up or down. When I press the switch I hear a clicking in the door, but nothing happens. a good whack on the armrest or slam of the door and the window motor energizes and the window drops a few inches, and then it's good to go for several more days. Before I pull the door panel, is there anything in particular I should look for? I know it could be anything from motor brushes to loose connectors, but is there anything in particular I should know to cut down on the troubleshooting time?
Thanks for any advice/input.
Old Dec 11, 2014 | 02:05 AM
JagV8's Avatar
Your era car will have the parts that fail with time so you may well need to replace some (usually not the motor). Might want to have them ready. Someone may have an ebay link
Old Dec 11, 2014 | 03:51 AM
Paul792's Avatar
The window regulators are known to fail. So, this might be the problem.
This link to changing the rear window regulator should help check out if it is or not the problem with your car.
https://www.jaguarforums.com/forum/s...ics-faq-57126/
If you need a new one. The link below may be cheaper with airfreight than buying in Australia from Jaguar.
Front Power Window Regulator w Motor Passenger Side Right RH for 00 02 LS s Type | eBay
Old Dec 11, 2014 | 01:11 PM
tbird6's Avatar
Does it make any sounds going up or down?
As posted above I would put replace the window regulator on your repair list. It's a very minor and easy repair. Some people can do the entire thing in less than 30 minutes.
You are lucky because the Gen I cars use the same front window regulator as the Lincoln LS. So the entire regulator is only about $60-$90 on EBay and Amazon.
Old Dec 11, 2014 | 06:11 PM
Normally it's fine, no noises or problems. It really just seems like an electrical issue. the clicking is a relay in the door, but the motor just doesn't respond. Vibration fixes it. I guess I'll have to pour over the electrical and service manuals to get an understanding of how it all works.
Old Dec 12, 2014 | 02:56 AM
JagV8's Avatar
It doesn't have to be the plastic parts but if they're breaking then maybe they jam the motor and it current limits as it would with a hand or head in the way of the window.
Old Dec 12, 2014 | 07:54 AM
aholbro1's Avatar
Your symptoms are synonymous with a broken wire at the door-to-cabin transition but in my case it affected all four windows, not just the driver's. Check if your others work when the driver's is on the fritz. Also, that's a good place to look if the problem gets progressively worse and one fine day the window quits working altogether.
Old Dec 12, 2014 | 12:44 PM
Excellent suggestion. Will wait to try this before pulling door panel.
Old Dec 12, 2014 | 10:54 PM
It's the motor. Brushes or internal wiring. Power to it, but nothing happening until you give it a rap. Doubt you can get just the motor, and those things aren't designed to be repaired. So new assembly required. Thanks for the suggestions everyone.
Old Dec 17, 2014 | 09:45 PM
I had some time today and so decided to check out the motor issue further. The motor was otherwise in good condition, but the brushes pretty much gone. Unexpectedly, the motor does come apart very easily, and replacing the brushes would be a snap. So I modified the brush holder a bit to give me a few dozen more cycles on the nubs end of the brushes, cleaned up the commutator, greased the shaft and ordered generic replacement brushes off ebay for 5 bucks. I suppose most guys would just swap the motor, but I prefer repairing things as much as possible, and pulling this motor is very easy.
Old Dec 20, 2014 | 02:07 PM
clubairth1's Avatar
Community Influencer
Good repair and please give more information as our cars are getting older everyday.
Glad the brushes are available too.
99xk8guy
Sep 29, 2025 10:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
sadepol01
Sep 11, 2015 05:26 AM
