Intermittent No Crank/Start
Old May 14, 2018 | 09:32 AM
JeffreyRupp's Avatar
Default Intermittent No Crank/Start
2005 Jag S-Type 120,000 miles.
I have an intermittent starting issue thats getting worse. I turn the key, no crank, no start. Battery is fine. This doesnt happen every time I try to start. It does usually start fine but sometimes wont do anything except I do hear the relay click and a high pitched humming under the intake manifold, all electrical systems come on and work fine. Its recently gotten worse, about every other day. I have had it towed three times from work to my home and then it starts up fine the next morning. I dont want to pay hundreds or possibly over $1000 to a mechanic to figure this out. I am able to do some work on the car myself and if I can figure this out maybe I can fix it. Have a new starter ordered and it might fix the problem but wont really know until it wont start again. No check engine light and no codes on the OBD2. Anyone familiar with this issue and a fix?
Old May 14, 2018 | 11:03 AM
kr98664's Avatar
When it acts up, look at the indicator lights on the shifter J-gate. If P or N is not illuminated, the starter is inhibited.
If you don’t have P or N on, that means the computer thinks you’re in a different gear, based on position feedback from the transmission. If so, the most likely culprit is loose bolts where the shift cable mounts to the transmission.
Old May 14, 2018 | 10:18 PM
Got home tonight after work and tried to start it. Indicator lights on shifter were at P before start and lit up. It wouldnt crank, like before. I put it in neutral and it lit up N and started right up. Put back in park and turned the engine off. Started right up in park. Keep on mind that I did try starting it in neutral this morning and got nothing. This is driving me crazy. I expect it to not start tomorrow morning but who knows...
Old May 15, 2018 | 01:07 AM
JagV8's Avatar
I'd check the 2 (8mm hex head) bolts on the trans side that hold the shift cable are there and not loose.
Old May 15, 2018 | 01:57 AM
kr98664's Avatar
I wonder if this could be a security system problem. That’s easy to rule out.
Lock the car with the key fob. Press the lock button a second time to set the alarm system. The horn should chirp once. Watch the little red light at the center base of the windshield. It should flash once every 3 seconds or so to show the system is armed. Now press the key fob unlock button twice to unlock all the doors. The red light should go out. Now hop in the driver's seat and turn the key to ON (Not start yet). The red light should come on solid ONCE for about 3 seconds and then go out. If it flashes anything after that, you've got a stored fault.
Old May 15, 2018 | 03:16 AM
JagV8's Avatar
Probably only need to press once, not twice, to unlock.
And just once to lock.
Old May 15, 2018 | 08:28 AM
Keyfob has issues. It will lock the doors and set the alarm but it wont work for unlock. Always have to use the key to unlock. This morning, in park, it didnt start. Tried a second time, in park, three seconds later and it started. Real head scratcher here.
Old May 15, 2018 | 11:34 AM
kr98664's Avatar
What about the red PATS light? What was it doing, both with the failed and successful starts?
Old May 16, 2018 | 09:31 AM
clubairth1's Avatar
Community Influencer
Yes the red light in the center of the dash up by the wind shield.
Is it flashing?
Old May 17, 2018 | 01:04 AM
Donna's Avatar
You might want to try this... It worked for me
https://www.jaguarforums.com/forum/s...solved-163245/
or
https://www.jaguarforums.com/forum/s...ically-172634/
B-rad
Apr 10, 2018 07:12 PM
okXJR
Mar 31, 2015 06:28 PM
Snorgasm
Apr 20, 2014 08:15 AM
Valguard
XJ40 ( XJ81 )
Nov 24, 2013 08:36 AM
JimFlorida
Jan 8, 2011 03:31 AM
