Jag Tech specific question: New Key
Old Dec 20, 2009 | 11:24 PM
phd12volt's Avatar
Default Jag Tech specific question: New Key
http://cgi.ebay.com/ebaymotors/2002-...Q5fAccessories
Here's my question, since these are 100 dollars online, what would i be looking at to add it to my vehicle??? And is it true about the bar code?? Would this be something that a dealer has to cut, or can a locksmith make it and program it? I have no problem going to the dealer, by the way. I have an original flip key and valet key, however i wouldnt mind having the 2nd flip key as the valet key is being used for a remote start bypass. (which i know i have to remove if i take it to the dealer to have new keys programmed) Thanks in advance.
Old Dec 20, 2009 | 11:55 PM
Bytor's Avatar
Not a tech, but that looks a LOT like the key I just got for my 2003 STR. I have tried several lock smiths around town and all said that they could not program the key.
Dealer wanted $550 for a new key ($350 of it was the remote and metal shank). I got mine for $130 (very similar to the one you are showing) from Transponder Island. I will still have to pay the dealer $200 for the programming and cutting of the key.
Mine came in two pieces and is in the original Jaguar packaging. No bar code inside, but there are bar codes on the packaging which will remain intact until I take it to the dealer for programming. Dealer quoted my 2-3 hours for the programming and they needed the car to do it...
I purchased my car used and it only has the one key with remote. I need 2 keys available...
Old Dec 21, 2009 | 03:19 AM
JagV8's Avatar
I found on another car (Porsche) that locksmiths could NOT cut blank keys I bought (the angles of cut required not being settable on their equipment) and furthermore that dealers were not easily persuaded to do so either, their reason (claimed as) being that if they cut it and it didn't work then it would leave a problem as to whether the blank was wrong or they'd cut it wrong.
I had a working key so stuck the issue on the back-burner i.e. never did resolve it
(These were not keys needing to be programmed into the car.)
Old Dec 21, 2009 | 09:03 AM
Brutal's Avatar
First key/remote programming should never be more than a flat hour programming fee. Second there should be no problem with that remote and key programming, but i have never heard/seen of a bar code needed for programming. Theres is nothing on the car to program a key remote and enter a bar code, thats just plain bs. You have to have ids/wds to communicate with the security locking module to marry keys and remotes(required on stypes, can marry remotes to other models without going to dealer, but not the keys)
Old Dec 21, 2009 | 10:13 AM
tbird6's Avatar
Thanks Brutal!! I was never sure just how the key programming worked? It is a bit more complicated than my previous cars.
Old Dec 21, 2009 | 12:17 PM
gbdiver's Avatar
Brutal, how does one marry a new remote to a 2001 S-type?
Mark
Old Dec 21, 2009 | 01:29 PM
JagV8's Avatar
He just said you go to a dealer who uses IDS/WDS.
Old Dec 21, 2009 | 01:33 PM
Bytor's Avatar
Brutal, is $200 too much for the key cutting and programming? Should I try a different dealer? I am currently looking at going to Millennium Motor Cars in Plano, TX. Any other Dallasites know of a better dealer to go to?
Old Dec 21, 2009 | 01:59 PM
H20boy's Avatar
I'd recommend Autobahn, but after the gas you'd spend coming all the way over here, you'd spend all the $$ you just saved. An hour should be around $150 out the door. For piece of mind, $200 isn't bad, and that is the cap...it could be less if you got lucky and they weren't busy when you arrived.
Old Dec 23, 2009 | 01:19 PM
JaguarSPD's Avatar
$200 is a little high if you already have the key. Shouldnt be more than 1.0hr of labor to program. Just depends how much they charge you to cut the key. At our dealer we dont charge to cut the key, just the programing.
philwarner
Oct 4, 2024 01:37 PM
XJsc-guy
Nov 23, 2015 01:56 PM
obwoodie
Sep 3, 2015 07:45 PM
d a
Sep 3, 2015 02:34 AM
