Jaguar Forscan can't connect to vehicle
Old Oct 16, 2025 | 12:11 PM
Juliexlyons's Avatar
Default Jaguar Forscan can't connect to vehicle
I have a Elm327 usb and have download the Forscan software with extended license. Elm connects to laptop but will not connect to car. It says can not connect vehicle. I tried on another vehicle and it connects as soon as I plug it in. The ignition is on the on position. It is reading the battery voltage in the lower right hand corner of the forscan software. I also check all the fuses.
Old Oct 16, 2025 | 12:33 PM
clubairth1's Avatar
Community Influencer
Forscan is for Fords?
Take a look no Jaguar's listed. The name is kind of a tip off too.
Forscan
Old Oct 16, 2025 | 12:56 PM
JagV8's Avatar
What Jaguar did it work on?
Old Oct 16, 2025 | 03:40 PM
xalty's Avatar
forscan works by finding known ford pcm calibrations. the only jaguars with ford pcms are 00-02 S-Types and even then it probably won’t ID it
Old Oct 17, 2025 | 05:45 AM
The other vehicle I connected it to was a Ford truck.
Old Oct 17, 2025 | 05:52 AM
Im trying to program a new key. I can not find a locksmith in my area and don't want to spend an arm and a leg at the dealer. I downloaded the Jaguar software but I have read it has to be a certain version. Also, im not sure the Elm327 will work connecting it. Does anyone know of any other software for programing 2003 jaguar s type keys that would work with the Elm327?
Old Oct 17, 2025 | 08:38 AM
JagV8's Avatar
I'm nearly 100% sure no such software is available for an elm-type device.
Also, there's nearly no demand for such.
Old Oct 17, 2025 | 09:46 AM
Don B's Avatar
I'm no expert on key programming, but I think you will need a Jaguar-compatible pass-through Vehicle Communication Interface (VCI) such as the Ford/Mazda/JLR VCM (not VCM2), Drew Technologies JLR Mongoose cable (or possibly a Mongoose clone), or another compatible J2534 pass-through device. The ELM327 does not have the bi-directional capability or data speed required for programming. Also, you will need Jaguar dealership-level software such as Jaguar Land Rover Symptom Driven Diagnostics (JLR SDD).
But be aware that attempting to program a key on your own can easily lead to loss of all key functionality for all of your keys, which will ruin your day. A knowledgeable qualified locksmith will probably save you a lot of potential trouble and shouldn't cost any more than even the least expensive compatible VCI.
Cheers,
Don
Old Oct 17, 2025 | 02:48 PM
The Voices's Avatar
Smile
clubairth1;2877868]Forscan is for Fords?
I'm sorry, I cannot resist !
If you are having problems with your Forscan, the tip off might be the only solution !
Old Oct 18, 2025 | 09:25 AM
clubairth1's Avatar
Please listen to the great advice above!
Your heading down the path of destruction and you can easily damage your car. Stop right now!
Nothing that works on a Ford truck will help with your Jaguar? Nothing is the same.
Old Oct 18, 2025 | 11:01 AM
xalty's Avatar
elm327 is a garbage interface. mongoose jlr clone will work for forscan and sdd
stephen44
Mar 14, 2025 11:17 AM
JAGUAR S-TYPE XS TD 2.7L
Oct 10, 2022 04:04 AM
scotsgeeza
Oct 13, 2021 09:47 AM
Blue Lion
Apr 21, 2011 09:12 AM
