Key Fob Now Working Right
Old Jan 2, 2013 | 08:54 AM
EZrider800's Avatar
Default Key Fob Now Working Right
I'm in a bit of a bind. I lost one key fob and now the other one isn't working properly. It seems to lock the doors OK but it doesn't want to unlock the doors unless you press repeatedly on the button and are standing right next to the car. We have changed the battery and it didn't help.
Can I buy a key fob off Ebay and have it programmed for my car? Do I need to buy a certain serial number fob like I did for my Cadillac CTS or will any S-Type fob work?
What about the blade (key)? Can you get those locally and have them cut for your car? How expensive is the blade and the programming? I hear it pretty pricy at the dealer, so do locksmith's have the capability to do this?
Thanks in advance!
Old Jan 2, 2013 | 10:00 AM
Jon89's Avatar
Typical behavior for a key fob that probably just needs a good cleaning. Take it apart, clean the circuit board, microswitches, and back of the rubber keypad with alcohol and Q-Tips, allow all parts to air-dry, then reassemble and test it. Whenever I do this, my S-Type key fob has always been restored to full operation....
Old Jan 2, 2013 | 10:37 AM
JagV8's Avatar
I guess you know you can just use the key?
Regardless, you could do with a spare and it'll be fairly costly. You can get some parts from online sites and get dealer to program (a tiny few locksmiths can do it, too).
Old Jan 2, 2013 | 11:24 AM
EZrider800's Avatar
Doh! The title of the thread should say Key Fob is NOT Working Properly!
Yeah, I'd like to buy a spare as well as get this one fixed or replaced. I'll try cleaning this one and see how it does.
Any additional info on cost and where to go to get the key blade cut and the fob programmed would be appreciated.
Old Jan 2, 2013 | 11:43 AM
EZrider800's Avatar
Looking at Ebay I see several used remotes with the control numbers listed. I'm assuming these control numbers are the numbers you need to know to see if it would work with your car so no programming would be needed?
Where would I go to find out the control numbers for my particular car's key fob in the unlikely event that I could find the exact same numbers on a key fob on Ebay?
Thanks in advance.
Old Jan 2, 2013 | 08:24 PM
eggman51's Avatar
I recently bought 2 x fobs from eBay for my 2002 S Type. One was $50 new and the other was $5 used. The dealership charged $75 to program both fobs. I also ordered a spare key through the Jag dealer; these keys have a transponder chip built into them that is mated to the car. The key was $175 at cost including programming to the car (my Dad used to work for Jag and gets most things at cost through the dealer). For MY 2003 + you need the "switchblade" key / fob combo. These can also be purchased off eBay, but I think you need to order the spare key through a dealer. I also think the switchblade fobs can be self programmed (meaning you don't need a dealer to do it for you; this is not the case with the < 2002 fobs.
Old Jan 3, 2013 | 12:51 PM
EZrider800's Avatar
Eggman,
The Ebay sellers say the 2003+ keys and fobs are NOT self programmable. They must go to the dealer or a Locksmith.
Old Jan 3, 2013 | 02:31 PM
eggman51's Avatar
Ahh.. OK, sorry... I thought they might be user programmable.
In any case, you can get the fobs off eBay. This will save a lot of money over ordering from a Jag dealer. My 2 fobs cost $55 for the fobs, $75 for programming at Jag dealer; total $130 for what would have been ~$600 through the dealer.
I ordered the key through the Jag dealer for $175, but I am sure I could have got it done at a locksmith more cheaply, I just didn't have time to hunt around any more.
When I got the car it only had 1 key, no fob... it is well worth it to have 2 fobs and 2 keys imo.
Old Jan 5, 2013 | 08:13 AM
NvmyJag's Avatar
Thanks in advance.
I went through all the code checking and finally decided to take the chance plus it was only $26.00. I put in my vehicle, received the remote, paid $75.00 for reprogramming and it works perfectly. The new remote also came w/a new battery. I had an independent shop perform the programming; they only need to have the IDS program to reprogram the remotes.
New Jaguar Key Remote Keyless Entry Fob New in Bag Bottom Half Only Flip Key | eBay
philwarner
Oct 4, 2024 01:37 PM
Sprayall
May 30, 2021 08:13 AM
XJsc-guy
Nov 23, 2015 01:56 PM
philwarner
Sep 5, 2015 10:05 AM
Sprayall
Sep 3, 2015 07:49 PM
