Muffler Delete
Old Oct 17, 2011 | 10:07 PM
Bmwm5lover's Avatar
Default Muffler Delete
So, I am curious if anyone's ever done it? It is a very common thing in the BMW world (my M5 has it) and it sounds great. Growls when you step on it and a nice melody when I cruise, without being obnoxious.
Basically, chop off the two rear mufflers, run a straight pipe and weld some tips.
Any sound clips?
When I searched I came up with STR's (no V6's) and most of them had magnaflows.
Thanks..
Old Oct 18, 2011 | 06:56 AM
bfsgross's Avatar
BmwM5lover, I believe some of us have deleted the rear boxes to only reinstall due to an overbearing drone in the cabin. I personally haven't performed this but others who tried may chime-in. Thanks otherwise.
Old Oct 18, 2011 | 07:16 AM
SC Str's Avatar
Bacardi 151 had them on his STR and believe that they are for sale in the Private Sale section of the forum.
Old Oct 18, 2011 | 08:18 AM
Michael Star's Avatar
I did it to mine. Drone is low in cabin at freeway speeds (the wind noise is louder at 80mph). Car is still pretty quiet even without the rear mufflers. When I took it to the Texas Mile earlier this year, there were a few people that wanted to know if it still had the stock exhaust on it because it was so quiet.
Old Oct 18, 2011 | 09:35 AM
Bmwm5lover's Avatar
Hmm, sounds like it may not be a bad way to go then. Ill have to give it a try and see I guess.
Are the mufflers clamped on, or do they need to be cut?
Old Oct 18, 2011 | 10:01 AM
Mufflers are clamped on, that is actually what I did first to see how bad it would sound. You can pull them off in about 10 mins a side just to see what it will sound like. On a side note, I did the same thing to my 540i/6 back when I had it.
Old Oct 18, 2011 | 03:42 PM
Bmwm5lover's Avatar
How did you find the sound to be with the removed mufflers on the Jag
Old Oct 18, 2011 | 04:18 PM
I like it. It is def louder, but not as louder than the Mustang (long tubes, x-pipe, single chamber mufflers).
Old Oct 18, 2011 | 08:47 PM
bfsgross's Avatar
Mike. Do you have hi-flow cats, x-pipe, delete center resonator? In other words; what exhaust do you have aside from no rear boxes?
Old Oct 18, 2011 | 09:57 PM
Nada, just no rear boxes.
<object style="height: 390px; width: 640px"><param name="movie" value="https://www.youtube.com/v/picasacid?version=3"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="https://www.youtube.com/v/picasacid?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="360"></object>
Old Oct 19, 2011 | 08:02 AM
SchultzLD's Avatar
O.k. just to clarify the OP has a 3.0.
So on that note I can chim in and say you will not like the sound. I did it when I first baught the car looking for more note. WOT it sounds GREAT, at itel it sounds GREAT. Everything else sounds like ***. I was embarresed to drive it normal, and it is WAY too slow to go WOT every time. If you like the Honda Civic Coffee can exhaust with a Ironing Board bolted on the truck lid thing then you might like it.
Edit: BTW, you can test this in less then 10 min. Just remove the rear section and go for a ride. The extra pipe and tips wont change the DB or sound much at all.
Old Oct 19, 2011 | 08:26 AM
bfsgross's Avatar
Wait a minute! Shultz brings up a very important point. bmwlover has a 3.0 V6, not a good motor when messing around with exhaust...very difficult to quiet down. I had an 02 X-Type 3.0. Modded the exhaust and regretted it. Bolted on lower restrictive exhaust manifolds from a 1989 Ford Taurus, placed a single dual inlet/single outlet cat from a late model Dodge truck V8 under the passenger floorboard. The stock cats cook these engines because they are directly bolted to the side of the block. I mistakenly used one duel inlet/single outlet cat from a Dodge V8. She flowed but the interior cabin noise/drone was very annoying and impossible to quiet down. If you must; use two inexpensive aftermarket "regular" cats, place one after the other (can't place side by side) under the passenger floorboard (this was performed by X owners). Don't use Magnaflow hi-flow cats, you'll lose too much back pressure. You may try this arrangement using the stock mufflers, then try aftermarket mufflers...My experience pal.
Old Oct 19, 2011 | 02:07 PM
Bmwm5lover's Avatar
If it is truly that simple to remove the rear boxes, then I will give it a try. I mainly wanted newer tips, figured the sound would be a bonus.
Old Oct 19, 2011 | 02:19 PM
bfsgross's Avatar
If sound is what your after, then remove the center resonator and pop on a set of Borlas's or whatever. You'll pick up a few ponies and the sound will be throatier with a droneless cabin.
Old Oct 19, 2011 | 02:37 PM
Bacardi 151's Avatar
I had them on a stock STR, no idea how'd they'd sound on a 3.0. There was a little drone on the highway, I didn't mind it, nor did my passengers...They're sort of still for sale but I have them in my possession until mid December...They're sitting in storage 1000 miles away...lol
boiler
US Southwest
Dec 20, 2025 12:38 AM
revauto
Sep 17, 2020 03:50 PM
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
baskervillema
Oct 1, 2015 06:43 PM
