Multiple misfires
Old Oct 29, 2014 | 06:04 PM
hijk's Avatar
Default Multiple misfires
Started the Jag (2005 S Type, 4.2L , VDP) on Saturday. Started okay, and after idling for 5 minutes suddenly began to run rough. Shutdown and restarted, but continued to idle rough. Pulled the following codes:
P0301
P0304
P1313
P1316
P0300
P0308
Any troubleshooting suggestions? I just purchased the Jag last month with 75K miles, and I have no idea if the plugs or coils have ever been replaced. But my assumption is that codes for multiple cylinders likely have a common cause other than plugs/coils ?
I've been chasing a evap emissions code fault for the last week that threw a check engine light, but didn't seem to affect the idle.
-H
Old Oct 29, 2014 | 07:21 PM
tony1963's Avatar
It is statistically improbable for multiple coil packs to fail at once. I would focus on a vacuum leak and the crankcase breather hose is the likely culprit.
Old Oct 29, 2014 | 09:37 PM
jagqueen's Avatar
Check the Battery. If 12.2v or lower, replace.
I have just had multiple misfire codes disappear after putting new battery in. https://www.jaguarforums.com/forum/s...pe-faq-123983/
Old Oct 30, 2014 | 09:17 PM
hijk's Avatar
Thanks for the quick response. I put a new Bosch battery in a few weeks ago and it didn't throw any codes.
Having some trouble finding the crankcase breather hose. Is it one of the hoses connected to the purge control canister?
Old Nov 16, 2014 | 01:15 PM
hijk's Avatar
Default Solved sort of?
Replaced gas cap , spark plugs and 2 ignition coils (1 & 8). Misfire codes have ceased.
Jag drove great for a day, then threw 3 codes and an occasional restricted performance message. I'll start a different thread for those.
Thanks for the help.
Old Nov 16, 2014 | 02:11 PM
JagV8's Avatar
To find parts read existing threads and/or free download JTIS the workshop manual
Old Nov 25, 2015 | 01:56 PM
Demmy22's Avatar
2005 S-Type 4.2 with multiple cylinder misfire codes P0300, 0301, 0303, 0305. Just changed the plugs and coils. The codes went away for a while but it's back. What else could it be?
Old Nov 25, 2015 | 02:13 PM
JagV8's Avatar
Air leak?
Check fuel trims. See previous threads, there are dozens possibly a hundred...
Or blocked cat. Start with fuel trims...
Old Nov 25, 2015 | 02:30 PM
Demmy22's Avatar
Thanks for your prompt response will work on those ideas.
Old Nov 26, 2015 | 08:30 AM
Gus's Avatar
Gus
Did you do a hard reset after you replaced the sparkplugs and the coilpacks? If the battery was still connected when you performed your work a hard reset may be in order.
aode06
Jul 28, 2023 02:26 PM
LilaJagHubby
Oct 1, 2015 01:47 AM
JTC3400
Sep 29, 2015 05:03 PM
reb1999
Sep 26, 2015 08:41 AM
