Is it my FOB or door lock causing alarm?
Old Aug 26, 2022 | 06:14 PM
mikesbaron's Avatar
Default Is it my FOB or door lock causing alarm?
2006 S-Type R
I noticed that I can lock my doors using my fob, but if I come back to the car after 10 mins or longer the key fob no longer works, I have to use my key to unlock the door. And then once it's unlocked and I open the door, my car alarm goes off! I can then immediately get it to turn off by pushing the unlock or lock button on my key fob. Once I get the alarmed turned off my key fob starts working again. But when I leave again I have to go through the working-not working-unlock with key-alarm blaring cycle all over again.
A key shop told me I need a complete new fob and program for it at the tune of $220. I started troubleshooting and found that my left passenger door's lock actuator wasn't working. Could this be causing the issues I'm having? I tried manually locking that door and re-locking and unlocking with the key fob but it doesn't seem to make any difference with the working-not working-unlock with key-alarm blaring cycle.
Old Aug 27, 2022 | 03:09 AM
Welcome to the forums mikesbaron,
I've moved your question from General Tech Help to S-Type forum. This is the place to post technical questions about your model.
Old Aug 31, 2022 | 09:26 AM
mikesbaron's Avatar
Anyone......is it my non working rear door lock actuator or a key fob issue?
Old Aug 31, 2022 | 10:10 AM
motorcarman's Avatar
All locks/actuators need to 'agree'. (be in the same state)
When one lock is different, an error occurs and the security system is NOT HAPPY.
Get the fault lock/actuator fixed and the rest of the system will likely work fine.
The driver's door module could also be faulty or have a LOW VOLTAGE problem?
Old Aug 31, 2022 | 11:39 AM
mikesbaron's Avatar
Thanks for this confirmation. Do you have a recommended supplier or source for me to get the door actuator?
Old Aug 31, 2022 | 04:06 PM
A salvage yard would be the most cost effective.
I sold my S-Type and only have X308 sedans And X100 4.0 SuperCharged Conv.s
I do have three X308 parts cars so I have my own salvage yard.
Old Aug 31, 2022 | 04:10 PM
mikesbaron's Avatar
My S-Type R only has 87k miles and this actuator has already gone out. I'd rather have a new actuator rather than trying my luck with another used one that might have even more use than my current broken one.
Old Mar 3, 2023 | 03:48 PM
Adamjg50's Avatar
Hi, I am having this exact issue. Did you solve the problem?
Old Mar 3, 2023 | 04:40 PM
mikesbaron's Avatar
I didn't fix it, but only because I sold the car but it was the rear door actuator itself. It's an expensive and time consuming fix; so complex in fact that the normal car guy I use for stereo installs didn't want to touch it.
Old Mar 3, 2023 | 10:36 PM
Adamjg50's Avatar
Hi. Can I as how you knew which door was the issue door.
I had to change something similar on my old land rover and know it's a painstaking issue but short of pulling the fuse out the horn I dont think I can live with this..
Thanks in advance
Old Mar 6, 2023 | 08:48 AM
mikesbaron's Avatar
I could tell becasue the offending door was not locking when I tried to use my key fob.
wierciu
Jul 4, 2022 12:01 PM
1sloXJR
May 14, 2015 09:04 PM
CMS
Apr 7, 2013 11:08 AM
robcouzens
Feb 12, 2009 08:51 PM
