OBD Scanner Required
Old Nov 2, 2012 | 08:27 AM
warpyb1's Avatar
Question OBD Scanner Required
Hi All -
I was driving last night and the amber warning light kept coming on saying Engine Fail Safe - it would then disappear.
Then this morning I started the engine up and it went to Red warning light and no power.
Limped back to the drive way - switched the car off and then back on and the error had gone. ??
Couple of questions - any one else had this ?
What type of code reader do I need to get to read any codes .
I have a S Type 1999 3ltr.
Help
Old Nov 2, 2012 | 10:19 AM
JagV8's Avatar
See General Tech forum.
Old Nov 2, 2012 | 10:29 AM
fix it's Avatar
OBD2 i think oo look i have one for sale
Old Nov 3, 2012 | 03:58 AM
warpyb1's Avatar
How much ? I brought one before from eBay but it wasn't compat with my model year.
Old Nov 3, 2012 | 09:08 AM
fix it's Avatar
£10 its one of them elm 327 bluetooth one's.
check your car is OBD2 First
Bluetooth Elm327 Scanner OBDII OBD2 Diagnostic Scanner | eBay
Old Nov 3, 2012 | 09:57 AM
JagV8's Avatar
All S-Types are OBD2.
Old Nov 4, 2012 | 02:43 AM
warpyb1's Avatar
Even 1999 ? As I say the last scanner I brought wouldn't connect properly to mine as it was a 1999?
Old Nov 4, 2012 | 02:58 AM
Your 1999 S-Type is definitely OBD2.
Your issue with the scanner is a number have been found to be incompatible with OBD2 Jaguars and some will return false codes. The thread https://www.jaguarforums.com/forum/g...-%2A%2A-33347/ is a good place to check 'member approved' scan tools.
The last OBD1 standard Jaguar model I had was an XJ40. On the earlier OBD1 standard, fault codes were accessed by pressing the VCM button. Vehicles with OBD2 standard have a diagnostic port.
Exact changeover to the later standard varied between manufacturers and markets but was generally 1995/96. Broadly speaking, the difference is OBD1 only monitored entire circuits or components for failure whereas OBD2 monitors performance against a predetermined range.
Old Nov 4, 2012 | 07:48 AM
stanjag's Avatar
Default Elm327
Hi,
Is that your unit on ebay?
If not I would like to buy it from you, if the other member does not want it.
At £10 thats a good deal.
regards
Stan
Old Nov 4, 2012 | 03:37 PM
fix it's Avatar
Originally Posted by stanjag
Hi,
regards
Stan
yes its my one
jagtoes
Apr 22, 2016 07:37 AM
carl purchase
Oct 14, 2015 06:14 PM
Corycarlo
Oct 3, 2015 09:33 PM
jjmiah217
Sep 28, 2015 09:09 AM
