One. Simple. Question.
Old Mar 15, 2012 | 05:12 PM
cliff328's Avatar
Default One. Simple. Question.
O.k., folks. This is not a trick question. I'll tell you why I'm asking after I receive your answers.
You have a 4.2 litre S, normally aspirated. You put the car on a lift
and drain the oil and replace the filter with an official Jaguar filter.
You put the drain plug back in, tighten, and lower the car so it is
perfectly level.
The Question: How many U.S. quarts do you add to the motor
to bring the level on the dipstick to 'full'?
Old Mar 15, 2012 | 05:40 PM
Rebekah350's Avatar
???5.9 quarts oil and 1 quart of lucas???
Old Mar 15, 2012 | 05:45 PM
bfsgross's Avatar
The STR uses 6.25 quarts, same capacity?
Old Mar 15, 2012 | 06:13 PM
JagV8's Avatar
You add a bit less than the above then check the level and top up as needed. Start engine, run for a short time, switch off, wait, recheck, top up, etc. I would not measure the actual amount...
Some is always left in when you drain. The above works regardless of how much
I put paint marks on both filter and drain plug after tightening.
Old Mar 15, 2012 | 06:25 PM
6.5 according to JTIS, I don't measure, I fill to the mark run it for a few minutes, let it settle and top off.
Old Mar 15, 2012 | 07:04 PM
joycesjag's Avatar
Just shy of 7 US Quarts, that includes filling the oil filter prior to install.
Old Mar 15, 2012 | 08:56 PM
Mikey's Avatar
Nix on the Lucas. No snakes oils of any type needed.
Old Mar 15, 2012 | 09:09 PM
Rebekah350's Avatar
not to hijack the thread, but what about fuel system cleaners?
Old Mar 16, 2012 | 12:52 AM
vance580's Avatar
05+ STR takes closer to 7.5 quarts with the extra oil cooler. I would estimate it to be about 7.3. I end up buying 2 5qt jugs for an oil change then just get one for the next and use the 2.5 left from the first. Cheaper that way.
Old Mar 16, 2012 | 03:42 AM
JagV8's Avatar
Any decent oil of the right spec is fine. To clean the fuel system (really, the injectors) try .... hmm, I think it's called BG44 over there? Er, change fuel filter first as it's easy and cheap
Old Mar 16, 2012 | 07:28 AM
Mikey's Avatar
Nope, not in any car I own. Gasoline already contains all the cleaners needed.
Old Mar 16, 2012 | 08:18 AM
I've never used the BG44 but it's been recommended by several people here as being worth a try.
When is Cliff coming back to tell us what this is all about?
Old Mar 16, 2012 | 08:20 AM
joycesjag's Avatar
Drive by poster???????
Sleestak
Aug 17, 2022 11:22 AM
TreVoRTasmin
Feb 23, 2021 03:13 PM
CXJ
Aug 29, 2017 08:41 AM
MrWhite
33
Oct 22, 2015 10:29 AM
n8ertot
Oct 11, 2015 02:28 PM
