P IIII no dtc definitions found
Old Sep 10, 2011 | 01:16 PM
brianflartey's Avatar
Default P IIII no dtc definitions found
I have a 2005 s-type with 128k. It has been shifting strange lately, kind of hard shift I guess. Seems like a transmition problem of some sort. I had the car scanned at auto parts store and it threw the code
PIIII No DTC Definition Found
Does anyone know if thats related to the shifting problem?
Old Sep 10, 2011 | 01:29 PM
barney100golf's Avatar
try this web site it says P1111 System Pass, I do not know if this refers to S-Type but I would assume so if correct
Old Sep 10, 2011 | 01:31 PM
Most Complete List For Jaguar Check Engine Light Codes
Old Sep 10, 2011 | 01:33 PM
all the w's engine-light-help.com jaguar-check-engine-light
Old Sep 10, 2011 | 01:43 PM
you could also try this link which seems even better
http://www.gusglikas.com/images/Auto..._OBD_II_R2.pdf
Old Sep 10, 2011 | 08:00 PM
Default thanks
Thanks for your response. I don't know much about cars and didn't understand much of the link but it does appear that the code and the problem are connected. Is there a national chain you would reccomend as a trans shop? I have a local place I could use if not.
Old Sep 10, 2011 | 08:18 PM
BlackX300VDP's Avatar
P1111 means all good. The trans shifting may or may not produce a code. First thing I would try is going to a Jag or LR dealer (one that has a Jag tech) then have them do the trans adaptation clear then a readaptation. If this doesn't fix the concern then the nature of the concern must be checked. A trans module reflash may be needed. If all else fails and you need a transmission then call Mike at manhattaneuroparts.com. He can get a good price on a ZF reman trans. If you need any further help with it, give me a shout.
Old Sep 11, 2011 | 08:30 AM
JagV8's Avatar
Originally Posted by barney100golf
Please do not rely on those as many are WRONG. (Others are missing.)
Also, the correct codes - see the FAQs here - have far more data.
Old Sep 11, 2011 | 10:22 AM
Gus's Avatar
Gus
I recently moved everything from that page over to www.jagrepair.com I will be redirecting things when I finish my transfers.
Old Sep 12, 2011 | 03:47 AM
Gus, what a great website, so much info I am sure this will be very useful to others on my side of the pond
trosty
26
Dec 18, 2022 06:40 PM
danke
Mar 3, 2016 10:57 AM
sawduster
Sep 11, 2015 10:02 PM
al_roethlisberger
Sep 9, 2015 09:14 PM
carcycle
Sep 7, 2015 10:22 AM
