Question: Error Codes
Old Jun 15, 2011 | 06:33 PM
rcx2000's Avatar
Default Question: Error Codes
Vehicle: 2000 Jag S-type 3.0 6cyl
Mileage: 91,300
The check engine light is on and these three error codes were pulled:
  • P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
  • P1576 - Pedal Position Not Available
  • P1580 - Electronic Throttle Monitor PCM Override
Does anyone have experience with any of these? Any help or thoughts would be much appreciated.
Old Jun 15, 2011 | 10:31 PM
rcx2000's Avatar
To clarify the questions on the above post, we are looking for what these codes are specific to. Does each code have only one specific problem, or are there multiple things that could be wrong per each code? We recently purchased the vehicle and are new to the jaguar world.
Old Jun 15, 2011 | 11:13 PM
phd12volt's Avatar
p1580 is for TPS circuit fault. looks like you need a new tps sensor..
P1576 CAN data bus, accelerator pedal position (APR)
sensor - communication malfunction (probable cause) Wiring, APP sensor
420 and 430 codes are cat codes
These were all taken from a search on this forum.
Old Jun 16, 2011 | 12:33 AM
JagV8's Avatar
If you follow the new member rules (you were told them aas part of signing up) enforced by the site you'll then be able to download things such as the codes PDFs. Yes most codes can have several causes. They're detailed in the PDFs.
Old Jun 16, 2011 | 05:37 AM
JOsworth's Avatar
The OBDII system is not Jaguar specific. As with all cars, codes DO NOT tell you directly what is wrong, but only point you to the component that the system detects a "out of range" reading. Example: Miss-fire codes don't automatically mean you have a bad coil. They can be caused by other issues like a vacuum leak.
You codes taken together would lead me to check for connector issues at the throttle body. Search on throttle body and you should come up with a ton of threads about it and what components to check.
Old Jun 16, 2011 | 09:55 AM
Gus's Avatar
Gus
+1
Old Jun 16, 2011 | 07:46 PM
rcx2000's Avatar
Thank you for the information JOsworth and phd12volt. We appreciate your help in directing us to some possible causes and places to start.
Old Jun 16, 2011 | 08:44 PM
Gus's Avatar
Gus
I am attaching a photo with the TB plug, Remove the TB plug from the TB clean it with a contact cleaner ( I use CRC contact cleaner) make sure the electrical connections are clean and snug when installed. I hope this helps!
Attached Thumbnails Question: Error Codes-2000stype-tb.jpg
Old Jun 16, 2011 | 09:34 PM
motorcarman's Avatar
Your car is one of the early S-types and there were some issues with the throttle pedal assy. First it was the CREAKING pedal and then we had a rash of faulty PPS so there was a parts upgrade. You might need to clear the codes and if the fault returns you might need to replace the pedal assy.
bob gauff
Old Jun 24, 2011 | 03:18 PM
rcx2000's Avatar
Thanks everyone, this info has helped a great deal. We are not able to view photos yet, due to being so new to the forums. After the ten posts, I believe we can see the attachment.
We've been doing a lot of research and have found some great deals for parts online. Thanks for helping us get started!
Old Jun 25, 2011 | 02:49 AM
Cadillac's Avatar
That's good rcx ,
You can try our vendors that's surely be a lot of helps when buying parts
NALLEY
JPAM
Old Nov 2, 2016 | 12:42 PM
JagV8's Avatar
Post reported
Old Nov 2, 2016 | 03:21 PM
What is going on with the 'necro-posts'?????
bob
Bcrary3
Feb 21, 2023 04:29 AM
Shawn Svacha
Feb 6, 2022 04:53 PM
Terry H
Jul 4, 2017 05:48 PM
KarimPA
Sep 27, 2015 08:46 AM
tonyforman
Sep 10, 2015 07:23 PM
