Rear Disk Brake Advice
Old Jan 1, 2016 | 06:17 PM
jtfred's Avatar
Default Rear Disk Brake Advice
I'm replacing rear pads and rotors on my 2005 S Type 3.0. I didn't have any issue removing the caliper and it's frame, but I'm not able to get the old rotor off. AllData says there are retaining clips on a couple of the studs but I'm not seeing them. The rotor won't budge.
What do you recommend I do to get the rotor off?
Thanks for your help,
John
Old Jan 2, 2016 | 03:30 AM
JagV8's Avatar
Rubber mallet. It'll be corroded on.
Old Jan 2, 2016 | 06:44 AM
jtfred's Avatar
Thanks JagV8. I did try the rubber mallet. While it helped with my frustration, it didn't get the disk to release. I'm wondering if I would be safe using a gear puller to break the bond.
Thanks again!
Old Jan 2, 2016 | 07:10 AM
JagV8's Avatar
Probably, if it'll fit - but hit harder with the mallet...
Old Jan 2, 2016 | 10:46 AM
motorcarman's Avatar
Spray some penetrating oil on the center hub area and use a BFH if you are going to discard the old rotors anyway.
You might want to install a lug nut a few threads on the stud to keep the rotor from launching if it suddenly comes loose.
bob gauff
Old Jan 2, 2016 | 01:35 PM
Renocat's Avatar
Deal with this a lot. I agree with Motorcarman, penetrating oil and mallet, but also try using a butane torch to warm the center of the disc around the hub. I've had good luck with that. Be careful if using a hammer, I've watched slobs smash the lead threads of their wheel studs, ruining them, and making a lot more trouble for themselves.
Old Jan 2, 2016 | 03:14 PM
jtfred's Avatar
Thanks for the replies. Hitting harder as JagV8 said did the trick. The disks eventually popped loose and the rest of teh job went well thanks to what I have learned from this forum.
Thanks again!
Old Jan 3, 2016 | 01:24 AM
XK120Fan's Avatar
Default Mark II BRakes
I have the pistons out of the calipers and would like to replace the rubber seals and the dust caps. How do I do this? Does the piston need to come apart or do I just stretch the new rubber pieces onto the piston? Thank you in advance.
john
Old Jan 3, 2016 | 09:35 AM
Mikey's Avatar
john
You're looking for the classic S-type section. This is the modern 1999-2008 S-type area.
Frank Hires
17
Dec 29, 2015 11:11 AM
etachu
Dec 23, 2015 03:23 PM
Jaguar 1981
Dec 22, 2015 03:51 AM
S-type 2000
Dec 16, 2015 06:53 AM
Duncan2004
Dec 15, 2015 11:28 AM
