removing center armrest
I have a replacement armrest for my str but one torque screw is giving me problems will I have tr remove the whole center console to get the lid off as a piece of plastic from the console is blocking the torque screw I have posted a photo of the problem
My armrest latch broke a couple of weeks ago. I purchase a newer used armrest. I tried to get the arm rest off, but found that after you remove the 2 torque screws, there are bosses on the bottom of the hinge that prevents you from removing the hinge through the narrow gap between the plastic center console and the sheet metal that holds it together.
I didn't have time to figure out how to remove the center console, so gave up and replaced only the latch where the plastic cable holder had broken.
If you remove the center console, please post images of how you removed it and how long it takes.
yes I had to remove the air vent at the back of the center console you can get to from the rear passenger area it just pulls out I use a trim removal tool there are then 2 torque screws holding the rear of the center console remove those then all you need to do is lift the rear of the console high enough to get that silver torque bolt out then slide out the arm rest slide in the replacement and put it back together again job done I think with the 2 torque screws removed from the console I think it just un clips but it is not needed to remove the arm rest
this is the one I use they come in a set of 4 diffrent sizes they are fairly soft so don't damage your trim got them on ebay that back vent is quite tight Iused the tool on the lower part of the vent so prissed up one side then prissed the other side so pulled the bottom of the vent and gave a slight firm tug and it came out
bdragomir
Apr 26, 2016 12:17 PM
wa3ra
Apr 12, 2016 07:40 PM
JagSTR2004
Mar 31, 2016 08:22 AM
