replaced fuel pump now engine light is on
Old Jan 18, 2013 | 07:55 PM
jaguarlady03's Avatar
Default replaced fuel pump now engine light is on
2000 s type - i replacled fuel pump and now the engine light is on. any thoughts?
Old Jan 18, 2013 | 09:11 PM
QuartzSTypeR's Avatar
What's the code?
Old Jan 18, 2013 | 09:40 PM
Gus's Avatar
Gus
What he ↑ said!
Old Jan 19, 2013 | 07:58 AM
bfsgross's Avatar
Find code then reset to clear old "resolved" code. Likely nothing wrong.
Old Jan 19, 2013 | 08:02 AM
Default engine light on
the code is P 0102 - MAF low input. However, that code was present prior to replacing the pump without the engine light on ( i believe two differnet issues). the engine light only came on after i replace the pump and started the engine. the code is still present after erasing the code and re-reading.
Old Jan 19, 2013 | 08:10 AM
bfsgross's Avatar
Clean or replace MAF sensor. Or check it's electrical connection.
Old Jan 19, 2013 | 09:17 AM
Jon89's Avatar
Agreed. They are easy to clean - pull the electrical plug, remove two screws, and the MAF sensor pops off. Use a spray can of MAF sensor cleaner, available at any auto parts store. Be careful not to touch the internal element with anything other than the spray solution. Spray it thoroughly, let it dry for two or three minutes. Spray it again, let it dry thoroughly for ten or fifteen minutes, then re-install, clear the codes again, and go for a test drive. If the code returns, you may need to spring for a new MAF sensor....
Old Jan 19, 2013 | 11:41 AM
bfsgross's Avatar
Ditto. Rockauto.com ($100+ ?).
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
msdg137
Sep 16, 2015 06:24 AM
convincor
Sep 3, 2015 08:03 PM
Calhale
Aug 29, 2015 10:39 AM
