Running ruff
Old Mar 12, 2015 | 05:32 PM
Scottish Chap's Avatar
Default Running ruff
* 2003 STR, 48,000 miles.
My STR started running slightly rough 2-3 weeks ago—almost like it had bad gas in it. I’ve gone through three tanks of gas and only use premium so I don’t think it’s that. Symptoms include a gentle intermittent rattle at on engine idle and especially if the engine is cold (goes away after a few miles even if I stop and let it idle)
At very high RPM (fast acceleration in sports mode), it feels a bit rough and the check engine light will blink maybe 10 times, and then everything will go back to normal. No codes are showing (amazing for this car!). MAF? Spark plugs? Any thoughts would be welcome.
Old Mar 12, 2015 | 05:48 PM
JagV8's Avatar
Flashing MIL = misfires so terrible they're damaging the cat(s).
Will also be why it's rough. Probably an air leak - check fuel trims. If not, try the coils & look in plug wells.
Old Mar 12, 2015 | 06:06 PM
Thanks. Is the car safe to drive gently while I figure it out?
Old Mar 12, 2015 | 09:37 PM
NBCat's Avatar
You may have oil fouling the spark plugs and coil packs causing the misfire.
Have the cam cover gaskets and spark plug well seals been replaces recently?
Old Mar 13, 2015 | 02:47 AM
JagV8's Avatar
I wouldn't drive it till fixed since I wouldn't want to be replacing cat(s)
Old Mar 13, 2015 | 10:05 AM
Thanks for the post. No, they have not been in the ~3 years I have owned the vehicle (at 20K, now 48K miles).
Old Mar 13, 2015 | 10:08 AM
I finally got a couple of codes today--misfire codes: P1316 and P0308 (cylinder #8). Question for you: coincidentally, the supercharger started sounding more 'whiny' the last 2-3 months before the recent slightly rough idle started, and I swear the gears seem not to be up-shifting until slightly higher RPM (hence maybe the more prominent SC sound). You think this is related?
Will report back.
Old Mar 13, 2015 | 10:11 AM
JagV8's Avatar
Why worry, just fix it
Old Mar 14, 2015 | 04:15 PM
NBCat's Avatar
After the vehicle cold-soaked, remove the coil from the no. 8 cylinder and see if there is any oil contamination in the spark plug well. If there is, the cam cover gasket and spark plug seals must be renewed.
If you find no evidence of oil contamination, swap the coil unit with another cylinder and then see if a DTC sets for that cylinder. If it does, replace the coil unit.
Under no circumstances is the vehicle to be driven if the MIL is flashing as catalyst damage is occurring.
Old Mar 14, 2015 | 08:29 PM
Thanks for taking the time to post! To be fair, the MIL flashed only a couple of times when I gunned it...did not come on since and never with normal driving. Will not be crazy until it's fixed, and I'll let you know.
Old Mar 14, 2015 | 11:30 PM
NBCat's Avatar
Then let us both hope you do not see P0420 or P0430 as a DTCs.
Old Mar 28, 2015 | 09:37 AM
Default Fixed
Cylinder 8 was clearly misfiring. All four coils on the side where that cylinder is were replaced. No longer running rough, no flashing MIL (I've had it up to high RPMs since) and, in case anyone is interested (since it bothered me and I did not see anyone comment on it), the whiny sound from the supercharger has now dissipated. I'd love to see an explanation for that since that sound was the first symptom I noticed about two months ago before the rough idle. Hopefully it will help someone else...
Old Mar 28, 2015 | 10:07 AM
JagV8's Avatar
What were the fuel trims?
trosty
26
Dec 18, 2022 06:40 PM
cissdm
May 3, 2016 06:02 AM
Doovoe
Sep 8, 2015 05:42 PM
kevo
Sep 8, 2015 09:45 AM
