s type fuel tank
Old Jan 24, 2026 | 05:45 PM
jakesdad's Avatar
Default s type fuel tank
Need info please. On a 2005 s type, the fuel tank sits inder rear seat. On my car, the fuel pump is located under a rubber boot seal on rear passenger side. The rear driver side has a similar rubber boot seal which when removed, has a "cap" on top of tank with what looks like a nipple on top going nowhere. When I top off this tank, liquid fuel is dripping under the driver side rear seat. I can't see wet fuel there but it is stained and I highly suspect that cap seal is leaking. Can someone elaborate on what that driver side cap is on the driver side of fuel tank? Thanks
Old Jan 25, 2026 | 10:36 AM
kr98664's Avatar
Pictures? Year and engine?
I poked around eBay for comparison but pics of your arrangement would really help.
Old Jan 25, 2026 | 10:06 PM
joycesjag's Avatar
Under rhe black cap drivers side rear is tje fuel sending unit. Jpycesjag had an issue with the gas gauge. I replaced sending unit, a green larger o-riing (which just might be your problem) and a break off screw clamp that holds the seal to the sender and tank.
if you advance search "fuel sending unit by joycesjag" you will find a couple posts o e with the break away lamp and o-ring.
Old Jan 26, 2026 | 11:40 AM
jakesdad's Avatar
Thank you very much. I will look at that again. I did not see anything electrical under the driver side rear black rubber cap. But it would make sense if the leak was there. The passenger side where the fuel pump is looks clean and dry. Do you by any chance have a source and pt number for that o ring?
BTW....I am now wondering if that gas tank leakage could be the instigator of the 0174 and 0171 lean codes? Yesterday I also got a code for small evap leak and note to check gas cap and piping.
Old Jan 26, 2026 | 02:08 PM
joycesjag's Avatar
The wires between fuel pump and sending unit are located inside fuel tank itself. Check the link provided for part numbers back in the day and where I purchased. The nipple you inquired about u der the drivers side black cap in op is useless in our 2005's.
Old Jan 26, 2026 | 02:09 PM
joycesjag's Avatar
Oops, post #16
http://www.jaguarforums.com/forum/s-...estion-191781/
Old Jan 26, 2026 | 04:40 PM
jakesdad's Avatar
here a couple pics. The passenger side is the one with electrical connectors on top. The driver side is the one with the nipple to nowhere, but I don't see evidence of a gauge sender there? The fuel always appears under the driver side when I top it off. I guess I could leave the seat out and fill the tank and see what I see. I suspect you are right about a bad o ring under that drivers side cap. A little intimidated about messing around with a fuel tank, but if it its a diy job , I'm able. I prefer to run this tank down to as empty as possible and then open it, but not sure how that cap come off to get to the o ring.
drivers side
drivers side
passenger side
passenger side
Old Jan 26, 2026 | 05:16 PM
kr98664's Avatar
Originally Posted by jakesdad
The driver side is the one with the nipple to nowhere...
The fuel always appears under the driver side when I top it off...
Try poking a small piece of stiff wire down that mystery nipple. I bet you will find it solid plastic inside, and thus no need for a cap. Perhaps that cover is designed for multiple vehicles and would be drilled out only if needed for a particular model.
If indeed the nipple is solid, that would confirm the leaking seal theory. Please see this thread for details on the special clamp securing the cover:
https://www.jaguarforums.com/forum/s...l-band-221643/
Old Jan 26, 2026 | 07:11 PM
joycesjag's Avatar
Karl is spot on with his link above. If you look closely at your drivers side under black cap its a "worm clamp" that when tightened clamp breaks off intentionally.
I have an extra o-ring in garage I will see if I find. The nipple again is solid inside.
Old Jan 27, 2026 | 06:01 PM
jakesdad's Avatar
I'm sorry, but I checked out the link you furnished and read all the comments about getting these caps off and now I am more confused. This seems like nobody really knows how to do this job and everyone is sort of exploring it. I'm lost. All I want to do is replace the green o ring. I don't get clamps that are designed to shear off when properly tightened. That makes them a one time use thing. I kinda doubt that even the jag service guys know how to do this repair on a 20 year old car. My tank was replaced with the recall but that was nearly 20 years ago. If the clamp is designed to break off, where do you get another? I am completely flummoxed on how to proceed. BTW even if I wanted to take it to a dealer, I lve in a very remote town that is more than 3 hours drive to the nearest Jag dealer.
Old Jan 27, 2026 | 06:13 PM
joycesjag's Avatar
I think I may have posted incorrect link. Let this link and start at post 24 and read each post to end. I did source my partscat the time from SNG Barrett
http://www.jaguarforums.com/forum/s-...-191781/page2/
Old Jan 28, 2026 | 10:44 AM
kr98664's Avatar
I'm sorry, but I checked out the link you furnished and read all the comments about getting these caps off and now I am more confused. This seems like nobody really knows how to do this job and everyone is sort of exploring it. I'm lost...
I am completely flummoxed on how to proceed...
Time to get ahold of yourself!:
Take a few minutes to read that thread again. Yes, you are correct, there is no perfect answer but several workable options.
That mystery clamp is indeed designed for one-time use. However, by prying the shear collar off, you will find a small hex (7mm?) underneath? With the collar out of the way, and lots of patience, the clamp can be loosened with normal wrenches. A socket wrench and flex drive may be needed. See post #13 at that link for a view once the collar is removed. If the clamp is removed this way, it can be reused. The only unknown is what torque to use for tightening. I would suggest barely more than snug, but I don't really know.
If you can't get the collar to pop off, you can still loosen the clamp with Vise-Grips or similar.
Another option for easier removal is to simply cut the band clamp with tin snips. See post #19.
If you want to replace the clamp with new OEM, you can get official part numbers here:
https://parts.jaguarlandroverclassic.../brand/jaguar/
Lots of different options for the fuel tank, so I wasn't sure which to select for your car. Once you get the Jaguar part number for your model, you can search online. I picked one possible number (XR857243) and found multiple vendors.
Another option is to replace the OEM style with a standard worm-drive hose clamp. Once again, no idea on the torque, so don't overdo it. A standard hose clamp won't have those spring areas, which are probably designed to help maintain clamping force, but I don't think that would be super critical.
Old Jan 28, 2026 | 11:43 AM
jakesdad's Avatar
ok, so sorry to bother again. I called SNG Barrett and the person on the phone seemed clueless as to what I was talking about. I sent him pic of the cap that needs to come off and o ring description. He is checking on it. In the meantime I searched ebay and found a seller with brand new s type fuel pump o ring for $31 and it is green and i assume that both caps on the tank port and starboard are identical and require same o ring. But I need clarification....if I'm getting this right, there is a true "cap" which is the center piece with the nipple to nowhere that must be pressed down over the o ring, and then a "locking ring" goes around that with a plastic worn gear that shears off at correct torque? Is that the crux of it, and the issue everyone has is removing the old locking ring because the worm gear has sheared off? Cant you just break off the old locking ring and lift off the cap? Help help help appreciated.
Old Jan 29, 2026 | 09:25 AM
jakesdad's Avatar
https://www.youtube.com/watch?v=qvPugcb7QGE
I do appreciate the feedback and help. Looking at mine, I see no evidence of a clamp at all. Please review the pic I posted previously. The good thing is that this car is not a daily driver. It's parked in the garage as a keepsake extra car, but I want to get that fuel tank leak corrected. I think it is contributing to emissions lean codes
Old Jan 29, 2026 | 11:08 AM
kr98664's Avatar
Looking at mine, I see no evidence of a clamp at all. Please review the pic I posted previously...
Ooh, it looks like you found the secret. In your pics (post #7 above) I saw the clamp on the passenger side. I never looked very closely at the driver's side picture and yes, we have no clamp!
Now the big question. Was the clamp accidentally left off during some previous work, perhaps during a recall? I don't think the clamp broke, as it would have stayed in position even if broken.
Looking more closely at your pics, are the rings white on both sides? The driver's side looks darker, but I can't tell if that is different material or just staining. Thinking out loud, but if the material is different, maybe it's a different design never intended to have a clamp, and now in need of some love. If the material is different, can you see if there's a groove where the clamp would have been?
Old Jan 29, 2026 | 12:26 PM
jakesdad's Avatar
Thank you for chiming in. I need the help. So, this car did have the fuel tank recall way way back and it was performed. I think they changed out the entire tank at that time. A few years ago, maybe 3 or 4 years, the passenger side was leaking and I took it to a local trusted indy shop and that mechanic replace the fuel pump assembl/cap/ring . He got the parts from Jaguar dealer. Again he is 3 hours away and probably would not remember the job at this point. So....it is now the drivers side which is suspected leak and I need to get that cap off to replace the o ring. How? I do not see a clamp.
Old Jan 29, 2026 | 01:18 PM
kr98664's Avatar
Do you see any provision where a clamp should have been installed? If so, and there's no clamp there now, you've probably been driving around for years without the clamp. Just a guess on my part, but perhaps the cap snaps somewhat into place and the clamp acts as insurance. If my line of thinking is correct, you may be able to gently pry the cap loose as is, since there is no clamp present.
Any chance the cap is partially dislodged? If not fully seated, try pushing down gently. Maybe with any luck it will snap into place and then all you'd have to do is add a clamp somehow.
Old Jan 29, 2026 | 03:29 PM
jakesdad's Avatar
well gang, I returned to the proje t and sprayed it down and wiped as clean as possible. The ring is black. The cap is white. The o ring is green and visible. And....I found the clamp and worm screw on the front side of tank. tucked nicely under the access port forward. I can see it, i can touch it. I have no idea how im going to loosen it. It looks as best as best as I can describe as a hex locking nut with a 4mm allen opening on the end. I stuck a 4mm allen in there and can almost get it in seated but after a few attempts, I decided to quit for the day to get my head around it. I really gotta hand it to the engineers on this one. They designed a clamp that intentionally breaks off and placed it where its a mindblower to remove it. Why wouldnt they just go with a flat cap that is sealed with a flat gasket and secured with small hex bolts around the circumference screwed down into the top of the tank?
Old Feb 1, 2026 | 12:18 PM
kr98664's Avatar
Any updates? Hope the project is proceeding a little more smoothly for you.
As far as the design of the clamp: Wasn't that part of a recall to install a redesigned tank? If so, the clamp would have installed before the new tank was installed.. Access down the road wasn't much of a consideration. If indeed part of a recall campaign, the official procedure for further access may have been to cut the clamp and replace with new. Access would be tight for a new clamp, but it would still have the breakaway hex so hopefully wasn't too bad with a socket and flex drive.
Remember, if you can pry off the base of the breakaway collar, there is a smaller hex underneath.
Can anybody please confirm how the clamp style ring and cap are removed? Does the ring thread onto the tank? Or does it snap straight on or off? The ring appears to be indexed to the cap, so the ring can't turn separately. Is that correct? On my '02, the cap is not indexed to the ring. The ring unthreads separately while the cap remains stationary, much like a big Mason jar lid.
Old Feb 2, 2026 | 11:48 AM
clubairth1's Avatar
Community Influencer
The 2005 S-Type had just one recall. It was for the fuel tank. Not sure this is your problem so see if any of the attached documents will help? It does mention the problem can cause leaks around the tank seals. Plus they mention fuel odors.
From the TSB:
Q2-Can you tell me more about what is wrong with the vehicle?
A-Investigations have determined that 2005MY North American specification vehicles may be fitted
with a fuel tank that has inadequate thickness around the apertures and/or dimension concerns
that could lead to aperture distortion around the seals. Where the tank aperture sealing is
inadequate it is possible for the On Board Diagnostic leak detection system to sense this and
could result in illumination of the malfunction indicator lamp (MIL) or a fuel odor. Fuel leaks are
most likely to occur only after a fuel tank has been fully filled with fuel.
TSB-R176.
Now the bad thing is the solution is a fuel tank replacement. Don't know if any new tanks are still available or not? Probably not. The recall usually is only good for 10-15 years after it's issued but again that can vary.
File Type: pdf
File Type: pdf
