S-type Front Brake Pads Install
Old May 5, 2008 | 05:30 PM
conipc's Avatar
Default RE: S-type Front Brake Pads Install
Nonsense. Just don't push too fast, being careful of the seals. Easy job...
Old May 5, 2008 | 06:01 PM
Trooperdad's Avatar
I opened the bleeder valve and attached a small plastic tube into an empty soda bottle and THEN compressed the cylinder with a "C" clamp. I heard from a mechanic that there is some kind of one-way valve in the line that could be damaged if you force brake fluid back up the line by compression. Another reason for bleeding it off is that you can replace old fluid with new (newer is always better than old brake fluid). I also read that same tech manual that said to discard the bolt...what for? So I didn't. Everything is fine so far.
Good luck!
Don G.
Old May 5, 2008 | 06:42 PM
cosworth's Avatar
The bolt isn't torque to yield. They say replace it so that they sell a bolt. Push the pads back in slowly. There is no one way valve. If there was - you'd put your brakes on and they would stay on.
Old May 5, 2008 | 08:58 PM
oilman151's Avatar
cosworth
You are 100% right. Fluid can only go one way, thats it.
Regards
Old Jun 5, 2019 | 02:13 PM
Samkpg's Avatar
Default Brake pad
I changed my brake disc and pads they put brembo disc and pagin? Pads now the wear I see there is a lot of space left on the inner surface
Any advice or link for brembo pads that fit the 2.7 diesel
I think these guys fit the wrong pads
Old Jun 5, 2019 | 02:22 PM
JagV8's Avatar
11year old thread for a different car and different issues!
I very much doubt yours has Brembo brakes and even if it has it does not need Brembo pads (or discs).
Whatever is wrong is less than clear.
Old Jun 5, 2019 | 02:30 PM
Samkpg's Avatar
The wear on the disc is not like the previous disc the inner circle has wider space and outer edge has no space
Sprayall
May 30, 2021 08:13 AM
PMKimpton
Aug 3, 2019 08:22 PM
Sprayall
Sep 3, 2015 07:49 PM
pocketrocket
Sep 3, 2015 07:44 PM
Dallas XK8
Sep 3, 2015 12:17 PM
