S Type Park Brake Fault
Old Apr 5, 2012 | 08:04 AM
Walter Brooks's Avatar
Default S Type Park Brake Fault
Hi there - checked forums the problem everyone seems to have is the brake locking ON. Here is the problem on my 2005 model - cruising along at about 60mph I notice the red park brake light flick on once, then the orange fault light came on together with the notification in the display.
The car is still being used but the park brake won't come on. Usual check on the fuses - all okay. Disconnected the battery [as a least invasive action]; left for sometime and then reconnected but with still no park brake; then took it to my local garage man who connected his computer to the car but could not find a fault [cables taught and did not seem disconnected]. Do I put fused power to the motor to see if it is working?
Is the motor or control unit at fault or does anyone else have any experience before it seems that it has to go to the dealer? Many thanks
Walter
Old Apr 5, 2012 | 08:09 AM
Mikey's Avatar
What happens when you attempt to engage the brake manually?
Old Apr 5, 2012 | 08:17 AM
JagV8's Avatar
Does he have jag-specific & S-Type-specific software? If not, he'd find nothing. The EPB has its own computer module and needs that special software. Without it, he'd be asking the engine about faults and you don't appear to have an engine fault.
(This is a polite way of saying it would have been a waste of time.)
Old Apr 16, 2012 | 08:24 PM
Theron Thompson's Avatar
I am looking for a shop to take my 2003 S-Type to, same issue that a lot of people post about the PARK BRAKE FAULT. Live in North metro and want someone who is experience and where I don't have to pay $250 for diagnosis from Jaguar dealer...any recommendations would be appreciated!
I changed the battery...also had the rear park brake looked at and it wasn't bad, so we didn't replace...? ANY suggestions would be helpful!
Old Apr 17, 2012 | 06:17 AM
What exactly is happening?
Have you tried the reset procedure?
Old Apr 30, 2012 | 06:55 PM
Bobby Brown's Avatar
Angry Jaguar SType parking brake fault
Hey all I have a slight problem, my 2003 SType has the dreadful parking brake fault. At first it was the annoying beeping sound when car was either unlocked or shut off and key out. Then it went from that to the light now comes on when started. The brake light and ABS light both came on. Now all three all giving me a headache. I don't want to start paying out the ying yang for repairs but if I have to I'm wanting to know the problem for sure. I tried to reset procedure but that's when the lights came on after. Maybe I did it wrong so please email me with the correct procedure and any thoughts of what might be the matter. Should I just take it to dealer !? I charged up battery also ... Thanks all who r willing to help me out .
Thanks Bob
Old Apr 30, 2012 | 07:17 PM
Gilly's Avatar
Hey Walter: Before going through the reset procedure, I would try taking your battery terminals as well as the ground wire off (on the frame), clean all the connections spraying the bolt on the ground cable with a contact cleaner/lubricant before putting back on. Make sure all connections are clean and secure. Then go through the reset procedure. I had a similar issue last winter and after this never had an issue since.
Good Luck!
Old May 1, 2012 | 01:25 AM
JagV8's Avatar
If that doesn't fix it then almost for sure your battery is no longer good enough for the computer modules.
Old May 4, 2012 | 10:26 PM
Hey guys I let a mechanic (local) look at mine and he said if its not the parking brake module it most likely is the brakes/rotors/pads being worn badly. This is mostly my problem I c how it could easily have set the fault off. Don't know but i do need new brakes bad.
Old Jul 24, 2012 | 01:41 PM
We tried the reset procedure....is there a link to other reset procedures? Thanks!
Old Jul 24, 2012 | 02:13 PM
JagV8's Avatar
What other one? Don't think it exists.
Have you made SURE it's not power (usually battery) to blame?
Old Jul 24, 2012 | 02:56 PM
Mikey's Avatar
Not sure I agree. Many of us have worn rear pads and rotors down to their service limits or worse with no EPB problems. The EPB system has no idea if the components are worn or not- the calipers have a self adjusting system to compensate for wear.
Old Sep 21, 2012 | 02:01 PM
kevin6451's Avatar
SAME PROBLEM HERE. JUST DISCONNECT THE NEG CABLE TO THE BATTERY, WAIT 10 MIN, PUT BACK ON, START THE CAR, IT WILL TELL YOU TO APPLY BREAK AND PULL UP ON ELECTRONIC BREAK HANDLE. i HAVE TO DO IT REGULARLY. Let me know how that works for you.
Old Sep 22, 2012 | 10:50 AM
Talking Found the problem
Hey gang I found out why my light is on. After mechanic replaced brakes and rotors. He found that one of my emergency brake cables was snapped which most likely cause the sensor to trigger. I'm in the process of replacing both cables and hopefully that'll fix it. (Cross fingers) lol. Thanks and if it doesn't fix problem i'll be sure to let you all know.
Bobby Bee
Old Dec 27, 2013 | 07:53 AM
Lou'S's Avatar
Walter
Hi Walter,
this week I had exactly the same problem, i.e. while cornering the red brake light came in shortly and after that two messages appeared, being Parke Brake Fault and Cruise Not Available. After that I did try all the known resets, but at no avail.
Have you been able to fix the problem and can you give me a recommandation?
Old Dec 28, 2013 | 02:49 AM
JagV8's Avatar
If it's a chafing cable you'd have to hunt for it. If a bad bearing, replace. If a failing battery, replace. You may have codes stored but if in ABS module you need a jag-type OBD tool to read them.
Old Dec 28, 2013 | 04:09 PM
manycars's Avatar
Just curious, how does that work?
My EPB regularly stops working for days at a time, then once in a while it will work all day or 99% of it. I tried the battery reset and it works only when I operate the EPB the first time. The second time it immediately goes in sulk mode and won't work again.
Old Dec 29, 2013 | 03:43 AM
Lou'S's Avatar
Thanks for all these possible answers, but how did you manage to solve this problem? I don't have a code reader for this, I can only read engine - and some ABS codes.
Most problems reported to the parkbrake can be cured by resetting the system according to the techn. instruction, but this is a different one. It occurred while driving.
Old Dec 29, 2013 | 08:03 AM
alan.crabtree4's Avatar
Default S-Type Park Brake Fault
A warning light stating Park Break Fault has appeared on my car. The Jaguar main dealer cannot find any fault in the park brake system and tried to reset the system to eliminate the warning light but the light stayed on. They have confirmed that they cannot see anything wrong with the park brake system...it works, it holds the car and disengages correctly on all wheels. Because the new MOT rules state that NO warning lights can be on, they have reluctantly refused to give me an MOT. They have suggested replacing the park brake motor at the cost of £260, but have made it clear this might not be the problem and it will be a matter of replacing all parts to eventually cancel the warning light????? Anybody with this problem?
Old Dec 29, 2013 | 08:38 AM
JagV8's Avatar
Sounds like they don't know how to read the module (or how to reset it). Change dealer (to an indy or other dealer) or splash out on a jag-type tool such as a Mongoose JLR.
Sadly a lot of dealers are pretty hopeless except maybe at new car sales. Most non-jag places have nothing that can read the module (and may or may not admit that).
You might try a new battery since the module draws a huge current and needs really good power. A battery's fairly cheap e.g. from Car Battery - Car Batteries - Motorcycle Batteries - Leisure Batteries - Cheap Prices! (they also sell on ebay and deliver).
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
Robert1968
Jun 24, 2017 11:16 AM
Lionrod
Aug 30, 2015 12:52 PM
