s type R airbag
Old Jul 12, 2016 | 07:28 PM
Kapitan1975's Avatar
Default s type R airbag
Hi
I m in need of some info,
I have just re do my headliner and repair a now working sunroof
Put everything back but then I find my air bag light is blinking then after sometime it turned to solid (stop blinking)
Question;
1. Is there any kind of sensor on the wiring harness above the headliner?
2. Is there a way to diagnose the issue ?do we need special tools?
Thank you,
Old Jul 12, 2016 | 08:00 PM
motorcarman's Avatar
The 'blinking' MIL is flashing CODE(s). Count the blinks and you will get closer to determining the fault.
A better way is to read the SRS codes with a compatible diagnostic tool.
Let us know the 'blink-code'.
bob
Old Jul 13, 2016 | 03:33 PM
I have 8 blinks before turning solid.
The first few blink was slower... Then turn faster
Old Jul 13, 2016 | 03:56 PM
JagV8's Avatar
Need the pattern.
Old Jul 14, 2016 | 03:35 PM
Pattern?
Like the blinking morse code.? Few long bonk then the short ones?
Can OBD2 scanner check this?
Old Jul 14, 2016 | 05:06 PM
Cambo's Avatar
There are ultrasonic sensors mounted in the roof lining and front A-pillar (and one in the center of the dash) to detect if people are actually sitting in the seats. If you have not reconnected one of those sensors after replacing the headliner you will have airbag faults.
Old Jul 16, 2016 | 11:38 PM
Thank you, I will try dropping the headliner again to see if any of the 2 sensor came off loose.
Does it matter if 2 are place in reverse of the original spot.
CBSmith
May 27, 2016 03:40 PM
richard1159
Apr 16, 2016 07:54 AM
joejag05
Apr 4, 2016 09:17 PM
steveo2003
Apr 4, 2016 02:49 AM
Hank03
Mar 30, 2016 04:10 PM
