S type Window regulator.
Old May 24, 2012 | 10:30 AM
Hawaiian Punch's Avatar
Default S type Window regulator.
Aloha,
I'm a few mins from ordering the regulator (Going with the stock ones on amazon for 79.00)
My question is, does the window regulators (LS and/or S Type) come with the window guides also?
or am I going to have to order the plastic guides separately?
Mahalo nui loa for the help.
Old May 24, 2012 | 05:50 PM
abonano's Avatar
Why don't you order the motor/regulator assembly from Rock Auto for only about $63.00 and as a forum member you get a 5% discount! Look at the vendor thread... Yes, the front door Lincoln LS motor/regulator assembly are interchangable with the S Type (Not the rear ones) and do come with the plastic guides - it's a complete unit - unbolt the old one and install the new one. (You might have to elongate one of the mounting holes...)
Old May 24, 2012 | 07:28 PM
Wow??! Nice brah!! Mahalo nui loa (thank you very much) for the help!!
Old May 24, 2012 | 07:49 PM
Gus's Avatar
Gus
And this is how you do it Link JagRepair.com - Jaguar Repair Information Resource
Old May 24, 2012 | 08:14 PM
abonano's Avatar
Your quite welcome!!
Old May 24, 2012 | 08:56 PM
BlackX300VDP's Avatar
Originally Posted by Gus
Nice write-up. Whenever we put in a LS (motorcraft) regulator, we just squeezed that one stud through the hole. Pretty much the same as you wrote. We did not notice a difference in failure rate for the replaced regulators, OE vs. Motorcraft, though. We saw the motorcraft ones fail over time. Hopefully by now, the plastic has been engineered to take the heat.
Old May 25, 2012 | 08:32 AM
Hooo Yea!!! Mahalo to you to for the great write up!! Now I can get this pau in no time!!!
Great help all of you! I really appreciate you guys taking your time away to help a braddah out!.
Mahalo.
Old May 25, 2012 | 10:08 AM
Amadauss's Avatar
I have found if you want to have the thing last, it was mentioned on here somewhere and I do it all the time, when you close the doors, make sure you have the windows closed and not opened. I guess in Hawaii you would have them open a great deal you lucky stiff .
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
