shifter stuck in park / please help
Old Jul 1, 2010 | 10:31 PM
texmanmoore's Avatar
Smile shifter stuck in park / please help
i need your alls help, I've read some threads and looks like a common problem with 01 s types. i was parked in the drive way that has incline , i had to pull down hard to get it unstuck from park, i was able to get it unstuck but am sure ive stretched the cable cause now it wont go in drive with out moving over to lower gear ,sure hoping it overdrive, What is the phone number for ordering the metal part to replace the plastic part under the shifter somewhere?? Is the shifter hard to get apart ?? Do you all agree that my cable is probably stretched? is that easy to replace ?? Any other parts that i need to replace ?? any advise would be greatly appreciated. thx
Old Jul 1, 2010 | 10:47 PM
motorcarman's Avatar
Common Problem. Here are some TSBs for you to read
bob gauff
File Type: pdf
File Type: pdf
Old Jul 2, 2010 | 01:32 AM
JagV8's Avatar
Search will get you answers
Old Jul 29, 2010 | 02:56 PM
jamie's Avatar
Having the same problem. Please send PDF's email (jamie@printsouth1.net) Thanks
Old Jul 29, 2010 | 09:36 PM
jaguars-type's Avatar
Hey guys I also had the same problem, this is what I did to make it work again. i have a 2003 s-type automatic , I remove the whole shifter, then I removed the cable that's connected at the bottom of the shifter it looks like a bicycle brake line, leave this cable disconnected when you go back to install the shifter, then I used a piece of plastic to keep the shifters locking SOLENOID on the open position, then re-stall the shifter, now the only thing is that you can shift the shifter with out the car being on, but it better then paying $400 for a new shifter.
Old Aug 5, 2010 | 10:47 AM
jamie's Avatar
All bolts on Trans are good, Cable OK. Just hard to get out of park when in a bind. Trans problems?? Please advise what next to try. Thanks
Old Aug 5, 2010 | 11:15 AM
JagV8's Avatar
Plenty of previous posts you should read.
You're making life hard for yourself by not putting your car details IN YOUR PROFILE.
Old Aug 5, 2010 | 01:01 PM
joycesjag's Avatar
contact ken@britishparts.com or go to their website www.motorcarsltd.com they advertise here and are a wealth of knowledge! Lots of people have dealt with them and not 1 complaint including myself!
Will P
Sep 19, 2018 08:36 AM
Rlover
Mar 30, 2016 10:04 PM
neruda
Oct 18, 2015 01:19 PM
Roger95
Sep 25, 2015 02:05 PM
GGabriel
Sep 18, 2015 08:44 PM
