Trans fluid
Old Feb 17, 2017 | 07:23 PM
Edgardo Melendez's Avatar
Default Trans fluid
Hy. I have a 2003 jag. Style 4.0.like to know which is the right trans fluid to used in this car.because I see many opinions. Pls someone let My know..thk...
Old Feb 17, 2017 | 09:42 PM
Dhorsley's Avatar
The type of fluid and instructions to check and fill should be on the transmission pan, under your car. I'm not sure what kind of fluid a '03 S-Type 4.0, but it should be a Mercon fluid, just depends on what specs.
My '01 S-Type's 5R55N transmission takes Mercon V. Check on your transmission pan to make sure.
Old Feb 18, 2017 | 12:45 AM
Datsports's Avatar
ZF life gaurd 6 is the correct oil for the 03 onwards models ; running the 6HP26 6 speed trans.
although there are other compatible fluids out there .
both jaguar and ZF will tell you there is not . mine is running fine on a total brand equivalent.
Old Feb 18, 2017 | 01:36 AM
JagV8's Avatar
If it's a 4.0 - and be sure to check - it'll have the 5R55N trans, which uses cheap fluid.
It's critical you check what engine it has. You can even look up the car by VIN on FordEtis home page to see.
Old Feb 18, 2017 | 08:15 AM
Default Trans flud
tnks guys I will check the tras oil pan to be sure..let you know ....
Old Feb 19, 2017 | 09:08 AM
Default Trans flud
HY.every one...DHORSLEY.. THANKS FOR your HELP. I DID WHAT YOU SAID.. CHECK THE TRANSMISSION PAN.I FOUND THIS #..ZF-GETREBE-GM11-0501-216-243B-PA66-GF35..AND IS 2003 JAG STYPE 4.2..WHICH TRANS FLUID USE.. IM NEW TO JAG.I HAVE THIS CAR FOR 2 WEEK. AND I LIKE.BUT I HAVE TO FIX SON STUFF.. THK .HAVE A GREAT DAY..FROM FLORIDA YOUR FRIEND. EDGARDO.
Old Feb 20, 2017 | 11:35 PM
n2audio's Avatar
I thought '03 was the first year for the ZF 6 speed.
With that trans, the purists will tell you to get the ZF Lifegaurd 6 fluid.
I, however, chose Ford's Mercon SP fluid. I ran that for over 10k before I sold it.
It had the lurch before and after. Otherwise, drove the same.
Old Feb 21, 2017 | 11:37 AM
Ducmon's Avatar
Here is a post on British forum about the oil for the gearbox. They have found cheaper oils which are the correct specifications and cheaper.
http://www.jaguarforum.com/showthread.php?t=81862
Old Feb 21, 2017 | 01:35 PM
Renocat's Avatar
You in the US, look for Ford Mercon SP,was made for the lincoln Navigator with the same transmission. You can get it for around $6 a quart at most auto parts stores, but will have to order it. Now Ford has supposedly changed that to a newer specification and I haven't read where it's compatible, so look for Mercon SP.
Old Feb 21, 2017 | 01:42 PM
joycesjag's Avatar
Originally Posted by n2audio
ZF 6 speed.
I don't believe there any purists here in the S Type family, especially when comes to finding alternate spec'd oil for these ZF boxes!
