Transmission
Old May 4, 2013 | 05:01 PM
paporindo.torres's Avatar
Default Transmission
Hey guys I just bought a 2006 stype. When I started using it it had the check engine light on. When I tried to run it fast it would tell me performance restricted, I notices it had no motor oil. Ok I put oil and it stopped, but know if i try to get speed quick at times i get this TRANSMISSION FAULT I get on side of road and turn it off and back on and works great again. I need help
Old May 4, 2013 | 05:40 PM
Welcome to the forum paporindo.torres,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center section to the S-Type section. Members here with the same model will be able to help with your transmission issue.
Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
Old May 4, 2013 | 10:25 PM
Michael Star's Avatar
Pull the codes. No oil is bad, transmission fault is bad, CEL is bad.
Old May 5, 2013 | 09:58 AM
What is CEL? Well i already pulled them, the codes were like oxygen sensor, air pressure, fuel pump and cadillac convertor, and i checked it many times but it does not give me any transmission codes
Old May 5, 2013 | 10:05 AM
CEL = Check engine light, you are going have to post the actual code numbers to get useful advice.
Was it engine oil or transmission oil you put in?
Old May 11, 2013 | 02:27 PM
Do u guys know how many o2 sensors does de jaguar have
Old May 12, 2013 | 10:50 AM
ONEsicJAG's Avatar
Help Us Help You!
Old May 12, 2013 | 12:47 PM
JagV8's Avatar
4 but they can vary. See below
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
dmatthewman
Sep 30, 2015 10:10 AM
Old_Doc
Sep 29, 2015 03:43 PM
