Transmission Failure? LOUD whining noise
Old May 30, 2015 | 12:39 AM
EN_VY's Avatar
Default Transmission Failure? LOUD whining noise
Hello guys, trying to see if anyone can shed some insight on an issue I'm having on an 05 S type with 160k ... I've been getting a gearbox fault message for a few weeks now. I'll drive the car, and if I aceelerate too fast, it will not accelerate. The engine light flashes for a few seconds, goes away, and the car goes back to normal.
Another thing the car would do is display a gearbox error message.. when it would do that, the car wouldn't shift gears. I would go up to 70mph, and the rpms would be at 6-6k, with no signs of wanting to change.
Today I was driving the car, reached a red light, light turns green, I try to accelerate, and nothing. I turned off the car, waited a few minutes, and was able to get the car home.. I notice the car is making a very loud whining noise, and giving out a smell (oil?).. While driving back home, I have trouble accelerating... Is the transmission going out? Does it need oil? I came across this, but not sure how true it is..
Jaguar S-TYPE Questions - WERE DO YOU CHECK TRANSMISSION FLUID - CarGurus
Thanks in advance.
Old May 30, 2015 | 06:41 AM
JagV8's Avatar
Flashing MIL = msifires so bad they're causing cat damage
And also probably annoying the trans.
Fix the misfires. Don't cause them until fixed unless you want to buy cat(s) as well (though you may be too late).
Old May 30, 2015 | 09:00 AM
Mikey's Avatar
In addition to the misfires, your transmission appears to need desperate help also. The link you provided indicated that the trans does not have a dipstick. This is true. There are many posts discussing here how to check the fluid level and more importantly that the fluid needs to be changed every 80-100K miles. Your car has 160K miles, it might have the original fluid.
Old May 30, 2015 | 07:39 PM
EN_VY's Avatar
Thanks guys... I turned it on today, started right up.. But as I drive it, it just does the same thing. The longer I drive it, the worse it gets.. I took it to a transmission place, and they told me it was going to be 2K to replace the transmission.. I really don't want to put that amount of money into this car, as I've had to replace so many things already.. I might just part ways with it.
Old May 31, 2015 | 09:06 AM
Mikey's Avatar
So the idea of checking fluid level does not appeal?
Old May 31, 2015 | 09:14 AM
NBCat's Avatar
Have you bothered to check the DTCs stored in the system to determine the source(s) of the misfire? As others have mentioned, find and correct the misfires before condemning the gearbox.
Do not drive the vehicle under conditions that cause the MIL to flash as there is catalyst damage occurring.
Old Jun 5, 2015 | 03:56 PM
Don B's Avatar
Hi EN_VY,
Not to be hard on you, but why are you still driving this car? It obviously has some very serious problems and continuing to drive it is only going to make matters worse. The gearbox fault message should be interpreted to mean "Stop driving this car until the faults have been identified and corrected."
If you will have the stored DTCs scanned and report them here, the knowledgeable members will be happy to try to help you sort things out, but until then, I would highly recommend that you borrow a car from a friend and let the Jag sit.
Bear in mind that standard OBDII scanners can only read most of the Powertrain (P) DTCs, but you may also have one or more proprietary Jaguar codes stored: U (Undefined, mostly network-related), C (Chassis) and/or B (Body). A Jag dealer or good indie mechanic who has the proper equipment can read the proprietary codes for you.
Please keep us informed.
Cheers,
Don
Old Jun 5, 2015 | 10:07 PM
EN_VY's Avatar
Thanks for the help guys.. @Don B.. yes, that's very true. I'm no longer driving it, (it doesn't run anymore) It runs for about five second and no longer moves. I will do this the DTC, hopefully I can figure it out.
Thanks again for the help.
PMKimpton
Aug 3, 2019 08:22 PM
1LowCat
Feb 23, 2016 07:19 AM
Horus
Sep 18, 2015 05:39 AM
AtholC
Sep 9, 2015 09:07 PM
mrplow58
Sep 9, 2015 11:27 AM
