Water Pump Install
Old Aug 30, 2012 | 05:41 PM
abonano's Avatar
Default Water Pump Install
Guys,
Any advice to the following would be greatly appreciated.
I am in the process of changing out my water pump - 2000 S Type - 4.0 V8
1) Jaguar lists 2 different size O-Rings for the water pump - 55mm and 70mm - for the life of me cannot remember if I pulled off an O-Ring on the old water pump and an O-Ring in the cavity on the engine block. (The replacement water pump has a thin metal gasket and an O-Ring)
2) The replacement water pump I ordered has the metal fins - does this mean I need to use different coolant due to potential cavitation?
3) Any other surprises I should be prepared for? I am also changing out the cross over pipe & gaskets, the 2" by-pass hose off the thermostat housing, the cap on top of the thermostat housing and the serpentine belt - also performing a full coolant flush and refill as well once I get everything together.
Thanks in advance - Anthony
Old Sep 1, 2012 | 05:48 PM
abonano's Avatar
In further digging on the forum it looks like the metal finned water pumps are upgraded to use only the thin metal gasket and NO O-Ring...
Old Sep 3, 2012 | 08:03 AM
chucky60's Avatar
Default Water pump
[QUOTE=abonano;572422]Guys,
Thanks in advance - Anthony[/QUO
Two years have gone by with the metal water pump on my car and I've had no problems.
dsnyder586
Dec 29, 2024 07:39 PM
1100me
Jul 24, 2023 06:10 PM
Saturbo
Sep 8, 2015 07:35 PM
kstevusa
Sep 7, 2015 01:12 PM
Sprayall
Sep 3, 2015 07:49 PM
