what does CATS SYSTEM FAULT mean
Old Dec 27, 2017 | 05:42 PM
ddovemurphy's Avatar
Default what does CATS SYSTEM FAULT mean
jaguar 2000 s type CATS SYSTEM FAULT message what does it mean
Old Dec 27, 2017 | 06:12 PM
abonano's Avatar
Means you have a code(s) logged from your CATS module and your struts are locked into hard position and your cat will ride like a stiff board.
Old Dec 28, 2017 | 03:50 PM
gm_jim's Avatar
You'll need to have it scanned by someone with a high end scanning system like AutoEnginuity with the Jaguar module added. CATS codes log with "C" prefixes (Chassis codes) - haven't seen a DIY scanner that can access those.
Old Jan 4, 2018 | 02:43 PM
Ducmon's Avatar
You could also use a mongoose clone and the Jaguar SDD/ICE programme but you would need to use a early version such as 1.30.
Have you the checked the connections on the top of the struts are in order. I have heard of them coming loose.
Old Jan 4, 2018 | 02:57 PM
JagV8's Avatar
Other ideas:
1. water in the trunk (boot)
2. low battery
Old Jan 4, 2018 | 03:06 PM
elviukai's Avatar
also corroded pcb on suspension ecu. it was case in mine XF also TPMS goes corroded same way as they are together (near airflow tunel to back passenger)
Old Jan 4, 2018 | 04:46 PM
JagV8's Avatar
Good thinking - but no TPMS in the S-Types.
Old Jan 4, 2018 | 04:50 PM
elviukai's Avatar
but there is supension ecu. and if the locating space same it vould have same problem. I went mad after measuting resistances of solenoids to short (according to SDD) but nothing shorted. so I disasembled suspensio ecu and saw corosion and coroded pacb tracks.
Old Jan 5, 2018 | 02:03 AM
JagV8's Avatar
That's why I posted about water.
Old Apr 6, 2022 | 12:23 PM
Smokinjoe187's Avatar
So where would that ecu be that makes an s type throw the cats fault code
Old Apr 6, 2022 | 12:25 PM
JagV8's Avatar
There's info on all such locations in the Electrical Guide - free download on this site or JagRepair.com - Jaguar Repair Information Resource
JimC64
Sep 22, 2025 02:52 PM
SableCat
Jul 14, 2017 12:42 PM
Jeff DeVere
Oct 13, 2016 07:00 AM
sjuraud
Aug 28, 2010 02:11 PM
Nov 29, 2005 10:42 PM
