What is "ERR" Code?
Old Jun 10, 2012 | 04:50 PM
Leonard_85's Avatar
Default What is "ERR" Code?
Hello all,
S-Type 2000 3.0 diagnostic plug-in reveals "ERR".
Has anyone experienced in the past?
Not discovered much on this forum about "ERR" Codes and their correct meaning.
My local official Jaguar garage appear to be clueless on the subject.
Regards,
Old Jun 10, 2012 | 07:39 PM
bfsgross's Avatar
Hard re-set then start again.
Old Jun 11, 2012 | 01:02 AM
JagV8's Avatar
Sounds to be the plug-in, whatever that is. Just doesn't work? Explain...
Old Jun 11, 2012 | 01:12 PM
Leonard_85's Avatar
Jagv8,
Well the Jag-techs finally unvelied codes!
Unsure how historical some these are - it's impossible to speak to techs directly. We're 100% certain water ingress beneath windscreen.
There are lots of codes. lots. See images.
J1850 - Communications bus fault
Two for the powertrain
P1233
P0733
B1617 - Battery voltage - this cropped up on almost all the ECUs. The battery was flat and charged prior to drive to garage though.
I want to tackle this myself just unsure precisely where to start.
Terrible weather in Old Blighty at the moment.
Thanks.
Attached Thumbnails What is "ERR" Code?-img071.jpg   What is "ERR" Code?-img072.jpg   What is "ERR" Code?-img073.jpg   What is "ERR" Code?-img074.jpg
Old Jun 12, 2012 | 04:30 AM
JagV8's Avatar
Flat battery complicates things. What a pain to have had that too.
So-called hard reset will clear almost none of those.
I'd clear the lot (you'll need a jag tool such as AE or the one the tech has) then see what comes back but do not let the battery go flat as you really do not need any extra confusion. Fit a new one if need be.
I hope you've stopped the water leak. If not, do that first as again you don't need any extra troubles.
You could check the PCM using any OBD tool to see whether it reflags codes. Avoid clearing any that come back till investigated & fixed. Note that it may not reflag any codes if it can't set all the OBD monitors (google and also read the codes PDF). If they haven't all set fairly soon then start to worry
Old Jun 12, 2012 | 03:24 PM
Leonard_85's Avatar
Thanks for your reply,
Dealing with the jaguar people has been very frustrating - like questioning technicians through a lawyer. I'm not sure I want them near the car atall. What a way to run a company..
"Note that it may not reflag any codes if it can't set all the OBD monitors" - not sure what you meant there...
Old Jun 12, 2012 | 03:58 PM
JagV8's Avatar
See the bit you didn't quote - starts with google
I bought AE so I could work on my own car. Without it you're stuck with a good jag place whether dealer or indy.
Old Jun 13, 2012 | 02:01 AM
Leonard_85's Avatar
Thanks for advice - can you recommend any units...
Also, the P0733 CODE - would this relate to the broken 4-3 prestroke spring I replaced 2 months ago. I assumed the codes self-cleared?
Thanks,
Old Jun 13, 2012 | 02:40 AM
JagV8's Avatar
Best to read the thread dedicated to OBD tools / make your own choice. I got AE but most won't spend the money.
I don't know, as I'm no expert on autoboxes and it's not the one in my car. Codes self-clear in multiple ways so read up and bear in mind what has happened and when with your car. It's by law not simple....
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
