Wont turn over out of winter storage
Old Apr 12, 2018 | 09:47 AM
Carlg07's Avatar
Default Wont turn over out of winter storage
2005 STR went into winter storage in Dec. started it up in Feb and let it run and drove for about an Hr.
tried to start in APR and it just clicks. New Battery last yr, disconnected took to garage put on charger for 24 hr.
still car just go click all instrument panel light on and dim when try to start.
in garage now cant get it out of park to roll car out for tow truck.
any suggestions?
Old Apr 12, 2018 | 11:33 AM
JagV8's Avatar
Battery is toast. Unable to hold charge.
Old Apr 12, 2018 | 03:35 PM
docs427's Avatar
check voltage, key off then check voltage headlights on, then check voltage when trying to start. minor drop with lights on, major drop with key to crank would suggest starter bad. //major drop with just head lights on would suggest battery. If starter indicated, try rapping it with a hammer a few times it might be stuck.
Old Apr 12, 2018 | 04:53 PM
abonano's Avatar
Yes, to Docs point. Battery first then take a hammer to starter if she still clicks with a known good or new battery.
Old Apr 13, 2018 | 02:03 PM
SinF's Avatar
Lots of things can happen in storage, however battery is always should be a suspect. See if you can find a known-good battery and try it with one.
If not, check all fuses. Also check for signs of vermin chewing on wires in the engine bay. Especially if you smell burning isolation or have unexplained multiple blown fuses.
Check coolant level - if lots of it missing, find out why. Also, if you feel ultra-motivated, remove spark plugs and try turning it over by hand. If you can't remove one belt at a time, until you find culprit. If all belts off, plugs out and it doesn't turn over - it is bad news bears. Squirt ATF into each cylinder and let it sit overnight.
As other pointed out, hammer can be used to persuade starter to get unstuck. However, expect it to not start again.
Old Apr 14, 2018 | 05:06 AM
Carlg07's Avatar
Battery was charged and load tested two times by different mechanic's and both times passed. Battery is only one season old less then 500 miles on it.
Old Apr 14, 2018 | 05:07 AM
Carlg07's Avatar
I will try the hammer gently
thank you.
Old Apr 14, 2018 | 06:35 AM
JagV8's Avatar
The miles are so low that unless the battery was on a suitable conditioner (not a traditional charger) it is suspect.
With LUCK you tried mechanics who actually grasp the needs of modern cars, but many do not and will wrongly pass a battery.
Old Apr 23, 2018 | 11:30 AM
Carlg07's Avatar
Just an update
Jag was sent to dealer by tow truck, when it got there they put the key in and it started
don't know why or how. they are running a diagnostic check to see if anything pops up
my only guess is that the starter sednoid might have hung up and the two loosened it up to engage.
Has anyone had this experience? I never got to swing the hammer but it probably would have worked. Thanks to everyone who had suggestions.
Old Apr 23, 2018 | 12:48 PM
phaelax's Avatar
I had a bmw do that. Starter went out, I tried for an hour but nothing. Got it towed from 2 hours outside of town, and it started right up at the shop. A week later it happened again and I insisted they replace the starter that time. No trouble since.
Sometimes I think just the bouncing around from the tow loosens up the solenoid.
Old Apr 27, 2018 | 07:25 AM
Carlg07's Avatar
everything checks out they cleared codes from battery out unknown why it wouldn't start.
battery checked out fine no issues
CRHINO
Apr 2, 2017 08:04 AM
FR_racer
Dec 9, 2014 03:06 PM
RichmondXK
Dec 4, 2010 02:33 PM
pu5hkar
May 26, 2009 03:28 PM
eaglexkr
May 13, 2009 05:52 AM
