Xkr rims issue
Old Jun 26, 2015 | 01:05 AM
Rambunctious Jaguar's Avatar
Default Xkr rims issue
Just swapped out my stock junos with some 20" xkr rims and now it smells like rear brake pads are burning up, i cant hear any rubbing, any ideas ??
Old Jun 26, 2015 | 06:15 AM
After driving it some more i think it is rubbing, hopefully alignment will help out
Old Jun 27, 2015 | 05:44 AM
JagV8's Avatar
Aren't the XHR rims just wrong (offset/whatever) for the car?
Old Jun 28, 2015 | 01:50 AM
Offsets 45 for both the junos and the sentas
Old Jun 28, 2015 | 08:55 AM
JagV8's Avatar
Which is quite a bit wrong I think...
Old Jun 29, 2015 | 08:58 AM
pab's Avatar
pab
Once again, here is the modern Jaguar wheel fitting guide
My karma just ran over your dogma
'08 Jaguar S-Type 4.2 "Satin Edition" (250.06 hp / 259.67 torque)
Jaguar - Vehicle Bolt Pattern Reference
(Jaguar _ Vehicle Bolt Pattern Reference)
On these pages you can find Jaguar vehicles Bolt Pattern and Offset. This will help you in determining High or Low offset and bolt patterns of your vehicle.
Discounted Wheel Warehouse has provided this information for its customers to provide the very best service to our customers. We offer a large selection of Jaguar Wheels and Jaguar Rims also Custom wheels, Car Rims, and Truck Rims so please enjoy the web site and choose your next set of Custom Wheels from Discounted Wheel Warehouse!
YEAR MAKE MODEL COMMENTS
2000 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2001 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2002 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2003 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
1988 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1989 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1990 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1991 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1992 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1993 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1994 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1995 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1996 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1997 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1998 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1999 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2000 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2001 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2002 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2003 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2004 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2005 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2010 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
1988 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1989 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1990 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1991 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1992 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1993 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1994 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1995 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1996 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
2010 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2011 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2012 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2013 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2014 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
1997 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
1998 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
1999 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2000 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2001 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2002 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2003 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2004 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2005 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2006 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2007 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2008 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2009 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2012 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2002 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2003 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
Old Jun 29, 2015 | 01:00 PM
tonykart's Avatar
pull the wheels and inspect inside, high probability you will see where they are rubbing, then you can decide what the fix will be.
Old Jun 29, 2015 | 01:05 PM
tonykart's Avatar
after a drive put your hand(or laser temp gun) on the rears, are they hotter than the fronts? They should not be. Also you can jack the rear and spin the rears to make sure there is no dragging.
Old Jun 30, 2015 | 03:21 AM
Thanks jagv8, pab & tonykart. The tires were rubbing agetting sliced by the inner fender lips, so i rolled the fenders and no more tire damage, so far atleast it still rubs hitting bumps but ill pull the fenders and should be dkne with the issue.
Old Jun 30, 2015 | 05:47 AM
GT42R's Avatar
What are the widths of the wheels front and rear?
Stock STR wheels are +60 front and rear, so that's a good deal more offset than stock, so no surprise they rubbed in the rear, must be close! Your stock Juno's may be +45, but +45 on a 8" wheel, vs a 9" wheel, is NOT the same thing, you cannot compare offset values directly to one another across different wheel widths...
They sure look REALLY good though!
Old Jun 30, 2015 | 09:09 AM
GT42R the front wheels are 255 and the rears are 285, ill post some more pics in a little whle, the cars stance looks very aggressive, best part is i got the wheels and tires for an awesomr price.
Old Jun 30, 2015 | 09:18 AM
GT42R's Avatar
Those rear Senta's are a 9.5" wide rim... Compare that to the 9.5" wide rear STR wheels, such as the Vulcan or Zues, which have are ET60... means your rears poke out an additional 15mm... Hence why you had rear fender clearance issues, which is quite commonly reported on here with owners playing with XF/XK and other aftermarket options...
Old Jul 4, 2015 | 06:40 PM
Old Jul 4, 2015 | 09:47 PM
GT42R's Avatar
^^^ uhh... yea....... case in point, the offsets on those really aren't appropriate for this car; that's an unacceptable amount of poke, yes, the wheel cambers on compression travel, but those really stick way too far out the fender....
Old Jul 5, 2015 | 02:41 AM
Yea but they look so damn good, i rolled the inside of the fenders enough to save the tires, i decided to not pull the fenders myself so ill post after i get em done
Old Jul 6, 2015 | 07:14 AM
GT42R's Avatar
Indeed, they look good, but they really don't qualify as fitting the car... Good luck on the fender pull, please keep us posted with progress, but I fear you risk quarter panel damage, and may have to resort to paint work at some point...
toronadomike
Jan 22, 2026 10:13 PM
FrickenJag
Jun 16, 2025 02:15 PM
slojotaa
Oct 16, 2019 10:22 AM
Skeeter
Sep 17, 2015 08:15 PM
obwoodie
Sep 3, 2015 07:45 PM
