No start 2001 XKR
Old May 7, 2026 | 06:12 PM
willtoliv's Avatar
Default No start 2001 XKR
Help, please. I have a 2001 XKR coupe. It has been having trouble starting. this problem has been getting worse for about 6 months. I could turn the ignition on/off two or three times before trying to start. After the the 3 tries it would start, but has been getting worse. Just had the plugs changed, replaced a bad coil. My mechanic is puzzled. He has been doing cars for me for many years and is very knowledgeable about Euro cars and Jags. I put a new air filter in. The last drive the car would stumble when you accelerated above 2500 rpm. Now it just cranks and cranks. I can hear the fuel pump in the tank cycling then stops. I do not know where the front fuel pump is located. My mechanic has a very good scanner and it troughs no codes . Any thoughts or diagnostic hints. Sure sounds like a fuel delivery issue.
Old May 7, 2026 | 07:55 PM
RJ237's Avatar
It sounds like fuel pump failure.
Old Yesterday | 03:04 AM
dibbit's Avatar
+1
In fact it sounds like both fuel pumps have failed - they are both located in the fuel tank - there is no front fuel pump. You need to test the fuel pressure at the Schrader valve on the fuel rail - there are lots of threads on this in the forum, but start here for your car:-
https://www.jaguarforums.com/forum/x...el-pump-85882/.
auburn2
Oct 26, 2025 11:46 AM
jokeruk
Jul 23, 2022 03:05 AM
auburn2
Jan 28, 2016 08:51 PM
jim graham4300
Feb 28, 2014 06:17 PM
XKRCoupeMan
Dec 12, 2009 03:55 PM
