US Northeast ME, NH, VT, MA, RI, CT, NJ, NY, PA
Need a shop in Maine to rebuild an engine
Old Apr 19, 2012 | 09:18 PM
SunnyJ's Avatar
Default Need a shop in Maine to rebuild an engine
Looking for advice on a shop in Maine with good experience rebuilding a XK8 engine. Posted a question in the XK8 forum on either replacing or rebuilding the engine of my 1999 XK8 with low milage. The overall opinion was the Jag dealer I use was too quick to recommend a rebuilt engine. The first step being to pull the heads to see what occurred when the engine overheated.
Old May 13, 2012 | 08:35 PM
dana0330's Avatar
The engine would have to come apart that engine may be a nickasil engine and it would be better to replace it. It would have to come apart to see how bad it is. I am a Jaguar master who worked at the dealer for 17 years and went on my own 3 years ago, if you could get it down to my shop I could look at it for you I am in Upton, Ma nott far off 495.
Thanks Dana
Upton Foreign Motors
Old May 14, 2012 | 05:38 AM
JgaXkr's Avatar
Dana you were a Jag master tech when you worked for a dealer. You are now a former Jag master tech.
Old May 14, 2012 | 10:07 AM
dana0330's Avatar
Once a master tech allways a master tech. That is just a tecnicality.
Old May 14, 2012 | 10:27 PM
SunnyJ's Avatar
Yes the engine is a nikasil engine. Since originally posting my need I decided to order a rebuilt engine to have our Maine Jaguar dealer install. Once the engine is replaced I will be storing the original engine in case this model reaches a more collectable level in the future.
Old May 15, 2012 | 11:09 AM
dana0330's Avatar
Sounds good I would have suggested a used engine, I have done a few and have had no problems with them.
Old May 15, 2012 | 07:32 PM
JgaXkr's Avatar
If you purchase the engine from a Jag dealer there is a $2500. core charge on the engine.
Old May 16, 2012 | 07:22 PM
SunnyJ's Avatar
The engine is a rebuilt used engine where all of the internal parts have been replaced and the cylinders have been lined. They have a core charge of $450 which depending on the condition of the engine that is sent back will be refunded back. Two year warranty on the engine.
Old May 17, 2012 | 08:28 AM
dana0330's Avatar
Were is the engine coming from? and how much is it? I know through Jaguar it is over $8,000.00.
Forcedair1
Sep 8, 2025 01:57 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
cissdm
May 3, 2016 06:02 AM
sogood
Sep 15, 2015 07:35 AM
rachelstr
Sep 3, 2015 12:59 PM
