2002 X-Type 2.5 brake, possible catalytic converter, etc issues. Need help please
Old Oct 5, 2014 | 08:10 PM
deviousgentleman's Avatar
Default 2002 X-Type 2.5 brake, possible catalytic converter, etc issues. Need help please
My brakes are feeling strange. The ABS light is not on unless I unplug a sensor. The peddle loses pressure and all of a sudden the brakes will work/catch creating a jerking feeling... I have bled them, and it didn't solve it. If I unplug the sensor the brakes feel normal, but obviously the ABS light is on.
Attached is a printout of a scan done at a shop that works on Jaguars. I was told that minimally the catalytic converters needed to be replaced, but the price they wanted was more than the car kelly blue books for in mint condition (found that to be odd, especially since a google search finds some brand new around the 100 range each...) They didn't mention what exactly was wrong with the brakes. They said it would take 10 hours just to find out...
Any ideas???
Attached Thumbnails 2002 X-Type 2.5 brake, possible catalytic converter, etc issues.  Need help please-cam00016.jpg   2002 X-Type 2.5 brake, possible catalytic converter, etc issues.  Need help please-cam00017.jpg
Old Oct 6, 2014 | 03:50 AM
Jac's Avatar
Jac
Before spending money on a catalytic converter, try replacing the O2 sensor.(The lower one against the firewall). Garages are so quick to tell people that their converters are bad. As far as your brakes, not sure. Could just be a vacuum leak by your booster. Seems like they break very easily.
Old Oct 6, 2014 | 03:52 AM
I recently replaced the o2 sensors...
Old Oct 6, 2014 | 03:59 AM
Jac's Avatar
Jac
I had the same problem with P0420. Replaced the senor and still had the code. I then put a spacer on first. Code never came back. It's been over 2 years now.
Old Oct 6, 2014 | 04:03 AM
Never thought of a spacer... I will look into that for the cats...
Old Oct 6, 2014 | 04:05 AM
Jac's Avatar
Jac
O2 Extender Oxygen Sensor Spacer HHO Test Pipe 1 Bung | eBay
Old Oct 6, 2014 | 12:21 PM
myexcursion's Avatar
unfortunately in my case the O2 sensor is S2 on the firewall side and I would swear it's almost welded on. I could not get it to budge and scared I would apply to much pressure on the wrench and snap something else on the exhaust system ! Barely any room to even slide to crow feet in and no leverage to turn... utterly horrible design !
Old Oct 6, 2014 | 04:16 PM
lindy8_man's Avatar
Recently had P0430 show up on my scanner. Found a recommendation to run a bottle of Mr. Gasket Cataclean in the tank. They retail for about $20. Pepboys has em 2 for the price of 1! Just finishing my tank now, and I reset the CEL. Now we wait...
Old Oct 6, 2014 | 04:30 PM
Dr dome's Avatar
Default pb blaster
Pb blaster the sensor. I got the crow foot from autozone. with a breaker bar and she came off real nice. I also took off the upper intake to make a little more room.
Also used the 02 spacers and they worked like a charm.
Thanks for that idea. I bought 8 or them. put them on all 4 of the sensors on both kittys.
The Dr!
Old Oct 6, 2014 | 06:01 PM
The Dr!
Thanks - I really would prefer not taking the upper off if I didn't have to. I'm also hesitant on how much PB I can spray down - Is that stuff flammable when the exhaust gets hot again ? It's a PIA just to get the stream to reach down that far with a little 4" hose
Old Oct 8, 2014 | 07:56 PM
Dr dome's Avatar
it will be fine. As long as you don't start the car as you are spraying.
Keep me posted,
The Dr!
Old Oct 9, 2014 | 01:40 PM
lindy8_man's Avatar
Just to complete the recommendation of the Mr. Gasket Cataclean, Burned through the tank of gas with the additive. No Joy, I reset the the CEL, and it came back on the following day. Moving forward with a replacement o2 sensor with spacer...
Cheers!
Old Nov 14, 2014 | 11:59 AM
Meouch's Avatar
O2 spacer definitely works - but be aware that the problem still exists - you just fooled the computer into thinking there is no problem - your emissions are still high and if there is any compromise such as blockage - you may damage other parts of the system - fix the problem asap.
So. I'm about to change my front cat - anyone have dimensions on flange bolt pattern? inlet/outlet size? overall length? going aftermarket universal - need info before taking things apart...
Old Nov 14, 2014 | 12:07 PM
I gutted the cats and put a spacer on the two 02 sensors that are on each cat. CEL is still on. Will scan and report. Something else I noticed after doing that is every once in a while I get a yellow light and display says cruise not available or something like that..
Old Nov 14, 2014 | 06:36 PM
How did you gut them ?? Did you remove all the piping , remove the Cats , gut and replace all back ?
Old Nov 14, 2014 | 09:14 PM
Part of the cat is bolted, the other part was clamped. Pull them off and bust up and push out all the inside contents.
Old Nov 15, 2014 | 05:32 AM
Too bad the Cats are so expensive that it's cost prohibitive for most of these X's. Between Cats and and Oil pan leak - you can pretty much blue book the car and have $ left over
Old Nov 15, 2014 | 05:43 AM
The cats alone would total the car out to me. That's why I gutted them.
Old Nov 15, 2014 | 07:14 PM
Wahooesprit's Avatar
If you have the ability to remove the cats you can boil them in water and citric acid powder--I did both of mine two years ago still runs great and no codes--replaced all O2 sensors first, all o rings on manifold and new plugs and no help the codes always returned until I took off cats...total cost was $160 to do both cats : $40 for 5 LB citric acid powder, $20 for propane tank (did on outdoor grill) and $100 for a 60 qt pot (you need this size for rear cat) boil each cat separate for 8 hours with half the citric acid in each batch and that's it ..
way2far
Aug 31, 2022 09:26 AM
Raul Lara
Sep 14, 2015 07:31 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
rachelstr
Sep 3, 2015 12:59 PM
