2005 X-Type Sportwagon 3.0 rear differential bushing
Old Mar 25, 2024 | 11:22 PM
JXR's Avatar
JXR
Default 2005 X-Type Sportwagon 3.0 rear differential bushing
I have an unpleasant clunk when going into Reverse. I have been told that the "rear differential rear mount" is going bad and that the part is no longer available.
I was also told that there is another bushing used in the suspension somewhere that can be adapted for use on the differential, specifically the "radius arm mount with sleeve".
Has anyone else heard that or have info on what parts are available.
I did see this offered from JagBits (Jaguar X-TYPE USED MOUNTING BRACKET FOR X-TYPE REAR DIFFERENTIAL - DIFFBRACKET-USED (jagbits.com) but I'm not sure if that's what I need to get.
Thanks in advance.
Jon
Old Mar 26, 2024 | 09:47 AM
dh53's Avatar
The JagBits link you have is for a dog bone shaped metal bracket that bolts to the frame and to the differential. It is used so will likely come with used bushings. There are 2 bushings in that part where it bolts up to the unibody, Jag part number C2S17304 that are available. I would call that the "rear differential front mount".
There is another mount in the rear center of the diff that bolts to the unibody. This is what I would call the "rear differential rear mount". I can't find that bushing in any parts diagram. No idea about substituting another bushing in there.
Old Mar 26, 2024 | 10:15 AM
dh53's Avatar
On the Jag XJ forum someone suggests the S-Type rear diff rear bushing is the same as other Jags of the 2000s. Part number XR813260. Maybe check they have a good return policy before buying?
Discussion in XJ forum here.
Old Mar 26, 2024 | 05:29 PM
Dell Gailey's Avatar
New part =
https://www.ebay.com/itm/23241975893...0&gad_source=1
C2S38951
https://jaguar.oempartsonline.com/oe...a&gad_source=4
Etc.....
Old Apr 1, 2024 | 01:29 PM
JXR's Avatar
JXR
Thanks. I'm not sure what the difference is between a "damper" and an "insulator" might be:
https://parts.jaguarcary.com/oem-par...lator-c2s17304
https://parts.jaguarcary.com/oem-par...amper-c2s23949
Is one on the top and the other to the rear of the differential housing?
Has anyone else had this problem on their X-Type?
Jon
Old Apr 1, 2024 | 01:44 PM
dh53's Avatar
The "damper" is just a slug of steel that hangs off the differential. The size and location cause it to damp out some unwanted vibration. That "insulator" could be what you need. Can the Jag dealer parts department confirm it is the "rear differential rear mount"?
Old Apr 10, 2024 | 04:16 PM
JXR's Avatar
JXR
Thank you dh53 for explaining that. The car is in the shop now having this looked at.
Old Apr 25, 2025 | 11:32 AM
PCjags's Avatar
As I have the same symptom, is there a resolution to this?
TIA
foleyaxle
Nov 10, 2023 06:31 AM
wesmc
Nov 18, 2014 08:17 PM
rjs5689
May 30, 2014 09:06 AM
drdnaga
Feb 3, 2013 11:47 AM
